I'm a newbie with this month's dumbest question!
  • I'm a newbie with this month's dumbest question!
    Okay, I picked up a couple of 12V/DC headrest LCD's for my rear passengers similar to the pic below (The power/video cable is what I am most interested in asking about here)
    The question: My wiring harness that came with each LCD plugs into the small DIN looking 3" cable coming out of the back of the LCD. Once plugged in, I then have one yellow plug (video) and another black female plug (power) on the end which is supposed to go to the video source and power source. My question is , what kind of cable plugs into the female power source jack and could I then proceed to run this directly to say the fuse box?
    Any links or pics would be beneficial ...thanks
    it may just be a female rca plug on the power cord.
    Can the yellow plug fit into the black plug??
    My first carPC!
    MP3/CD player
    Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
    Soon to actually find its way into the car!
      lets see a picture of the female power plug!
      i got dat ***** sittin on 22s! SUPERMAN EDITION!
        Okay, I ran out to the local electrical shop with cable in hand and found that this would be called an 'M-Plug'. Anyway, they had a plug like this:
        attached to a cigarette lighter adapter which could work in this case. However, I'm looking to run this directly to the battery, a distribution block or to the fuse box. I think you get the idea. Anyway, I am thinking about cutting off the adapter but I am not sure which wire would be the positive and which one would be the negative. Basically the female jack is a round connector with a single pin in the middle. It looks similar to say a coax cable in form.
          Whatever lead on the wire is going to the outside of the connector is usually neg and the center is usually pos.
          Visit my website at:
          http://www.hostilejava.com
          http://hostilejava.com/gerbil5.jpg
            Hey HostileJava,
            Thank you for that reply. Is there anything I need to worry about running it directly to the battery or via a power wire? The LCD is 12v/DC so I know I'm ok there, but someone mentioned something about needing to get the polarity before doing this, but I was under the impression that determining which wire is positive and which one is negative would be the same thing. Am I right in assuming this or am I misunderstanding polarity? Been a looooong time since I've done anything electrical.
              I am assuming you are building a carputer? In this case you would need something to handle the amperage; those wouldnt last more than a few seconds, either way. You would run a single power line to the battery. If it is going to handle all you power needs, 8 guage wire is a minimum... 4 is what I hear most people using now. I used 8 back in the day for a 300 watt audio system and it was fine, with a 20A fuse. It didnt last but ten minutes with a 15A fuse. I went through three 15A fuses. Im still a n00b, dont be discouraged.
              Carputer status: [-*---------]
              Im thinking laptop...
                  It's a monitor, not a 300W amp. I'm sure it will work fine on pretty narrow wire.
                  Just make sure not to install it to a circuit that will not be on when the car is off, or you'll drain your battery.
                    I was just covering bases... if the "video source" needs power too, might as well run his own fused circuit.
                    I assume you mean TO NOT install it to a circuit that WILL be on when the car is off...
                    But yea, if you just need to power them little lcds, no prob.
                    a carputer is a little trickier.
