Where can i get a driver?
  • Where can i get a driver?
    Ive lost my driver cd for my motherboard!
    Its a mainboard K7S5A!
    Any ideas? Anyone got one?
    Ive lost sound and everything!
    Another quality post from Dyl.
    Did you attempt to go to the manufacturer's website? I don't know a mobo manufacturer yet that doesn't have a comprehensive set of drivers for their boards...
    Try here, under the socket462 motherboards: http://www.ecsusa.com/downloads/down...to=Motherboard
    Make sure you know your mobo's revision number as there appears to be multiple revs of this board.
    How about the Wiki?
      if you just lost stuff such as your onboard video and sound cards, you should be able to go to their respective sites (creative if its a soundblaster sound card, and intel if its an extreme graphics card. these are most common of onboard devices) and grab the drivers. but id go with DarquePervert's suggestion first and get the recommended drivers for your motherboard. after you get all those drivers installed, and theres updated drivers for certain components elsewhere, then you can follow my directions and get the updated drivers.
      Your everyday carpc geek and tech guru at your service. *bow*
        also try www.driverguide.com
          I used to use www.ecs.com.tw , I might have one buried somewhere as I am using one of those boards, get back to me if you have no joy.
          Steve
          ....Yes, I know it has a stupid name, those crazy Japanese!
            Here you go.
            Click on Archive on the left hand side and find your MB and Version in the list. All of the drivers are there.
              driverguide.com needs a weird password/user like 'drivers' and 'all' but it is changed 'driver2' 'all' or something similar!!
              Carputer currently 'ghettoed' into car!!!
              EPIA MII-12000
              Ampie Case with rigged extra USB
              Hitachi 60GB
              Holux GPS mouse with iGuidance 2.0
              Lilliput 7" touchscreen
              Netgear WG121 USB WiFi
              Carnetix P1260
                I think it is
                L: driver2
                P: all
                  Thanks guy's Got it in the end!
                  Just a quick question again though! How do you stop xp's annoying popup's and reminders?
                  Really annoying! Never used xp before!
                    I certainly hope they used lubricant...
                    Depends on which ones you're getting.
                    There's a registry tweak that will turn off all the balloon help. There are other specific settings to turn off certain features.
                    Check the OS Optimisation forum. I distinctly remember it being gone over in these forums before.
                    How about the Wiki?
                      Thats... dark... and pervert too!
                        Desktop Clean up is in the desktop properties under customize desktop button. that is the most anoying if you ask me.
                          I try....
                          How about the Wiki?
