PCMCIA Adaptor?
  • PCMCIA Adaptor?
    I have a PCI expansion in my car pc but the case is so small you will never get a card in there.
    I have a Verizon Internet card that fits in a PCMCIA slot. Do the make a USB adaptor for some thing like this?
    Thanks.
    I'm not familiar with a Verizon Internet card, what exactly is it? Is it just a wifi (802.11) adaptor? Or does it somehow use cellular signals to connect to the internet?
    If it's just a wifi adaptor, you'd be better off to get a new usb wifi device as I don't think I've heard of a pcmcia -> usb adaptor.
      Card
      It is just a card for thier wireless internet service http://www.verizonwireless.com/b2c/s...edPhoneId=1517
        I had the same problem and the only solution that I can find is http://www.junxion.com/product/ but's it's pricey at $600 http://www.mobilitysavings.com/Catal...7_products.htm
        Apparently Kyocera is coming out with a similar box in a couple of months. Also, GTran wireless is supposed to have a USB based adapter, but I can't find anything on it.
        I went with the Junxion box.
        GRod
        Carputer/AV System ~95% complete
        Parts all acquired - testing underway
        Fabrication and integration underway
        More on my Ride
          I'm not sure about the height of your case, but a low profile PCI card may well fit if you remove its metal bracket and drill a hole for the antenna connector in the back instead. I have a wifi card in my 65mm high Morex case.
          CarPC status: HW all done, SW needs tweaked.
          Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
          Software: RR, MM/FD
            Thanks.
            No.
            How about the Wiki?
              but
              But there is a PCI adaptor for this correct? If that's the case then I'll get a different case!
                I don't know.
                Another option is to get a VIA MII-series mainboard. They have a PCMCIA slot.
                Software: RR, MM/FD
                  Yes.
                  First hit on Google: http://www.ambery.com/pcitopcadca.html
                  How about the Wiki?
