Proposed Setup - Please comment
  • Proposed Setup - Please comment
    VIA EPIA M10000 Mini-ITX Mainboard
    512MB DDR RAM
    Panasonic Slot Load DVD-ROM/CD-RW Combo Drive
    2.5" 80GB HD
    SB Audigy 2 ZS Sound Card
    Lilliput 8" VGA Touch Screen
    M1-ATX 90 Watt - Smart Automotive Power Supply
    OBD-II
    Win XP Pro
    4 port USB hub
    Shuttle Express Controller
    Hauppauge WinTV-PVR-USB2
    Some kind of navigation (any suggestions?)
    Is the M1-ATX power supply going to be enough for this system?
    Am I missing anything besides adapters for the HD and DVD drive?
    Is there any way to mount the sound card parallel to the motherboard (like an L adapter or something)?
    Please post any helpful comments, I would like to get a jump on this project soon and I want to make sure I get it right (for the most part) the first time.
    my setup - finally
    http://www.mp3car.com/vbulletin/showthread.php?t=50494
    hope u have better luck getting local tv channels with ur wintv card than i did!
      Get a flexible PCI extender for the Soundcard, this will then allow you to mount it parallel to the motherboard.
      For the power question - do a search for Power Calculator on the forums.
        I wouldn't recommend a flexible PCI extender. All you need is a standard 1U PCI riser card.
          do any of the usb connections use power, like do i need to add those into the calculations?
          my setup - finally
            how do i know how much power each component uses, i didnt see anything about power consumption for the mb in the manual, only that its 12 volts, no wattage specs
            my setup - finally
              anyone???
              my setup - finally
