m1-atx probs
  • m1-atx probs
    hi all,fitted pc in truck,put power to j11
    ignition to j12
    negative to j13
    turn key on pc powers up soon as i crank truck pc turns off same happens when i turn truck off,got jumper on(b)5secs/2 hours.
    cheers so it crashing windows every time it does this
    epia800 mobo
    m1-atx
    Morex Cubid 2699V
    120gig hd
    slim dvd
    512 133 ram
    Lilliput 8" touch srceen
    d-link usb fm radio
    Sound Blaster Audigy 2 ZS
    3usb 18card reader hub
    Umm...let's see...if I have properly deciphered your message, the PC powers on when you set the key to accessory or on, but shuts off when you crank the engine. Sounds like you need larger gauge wire from the battery to the power supply.
    System status: in progress
      i used the wires from my old stereo 12 and ing
      epia800 mobo
      m1-atx
      Morex Cubid 2699V
      120gig hd
      slim dvd
      512 133 ram
      d-link usb fm radio
        "12 and ing"? Huh? Can you be a bit more descriptive?
        Stock stereo wires are going to be a bit small for this power supply, for +12V and ground you REALLY want to run larger-gauge wire (around 10ga) to the battery.
          sorry,12 volt and 12volt ignition from old truck stereo
          epia800 mobo
          m1-atx
          Morex Cubid 2699V
          120gig hd
          slim dvd
          512 133 ram
          d-link usb fm radio
            Go ahead and use the ignition lead from the old stereo, but definitely get larger-gauge power cables run to the battery. There's likely too much voltage drop on the smaller gauge stock cables when you crank the engine, that's why the power supply is cutting out.
              cheers for that,just 1 more ?,getting interferance on monitor and through speakers when truck is running.
              epia800 mobo
              m1-atx
              Morex Cubid 2699V
              120gig hd
              slim dvd
              512 133 ram
              d-link usb fm radio
                Also, in my car, when you crank the engine, the power to the radio is cut anyway. I agree that you need the power cable run directly from the battery.
                : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
                : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
                : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
                  lead from battery now and working fine
                  epia800 mobo
                  m1-atx
                  Morex Cubid 2699V
                  120gig hd
                  slim dvd
                  512 133 ram
                  d-link usb fm radio
                    good to hear.
                    1990 Jeep Cherokee
                    2000 VW Golf TDI 4dr
                    2005 VW GTI MKIV - SOLD
                      Has the interference problem gone away with the new wiring as well?
                        no still getting it on monitor and through speakers when reving,the truck is diesel so didnt think i would get any.
                        epia800 mobo
                        m1-atx
                        Morex Cubid 2699V
                        120gig hd
                        slim dvd
                        512 133 ram
                        d-link usb fm radio
                          Try connecting the amplifier, PC and monitor to the same grounding point.
