a question about subs?
  • a question about subs?
    i know you think this is a stupid question but can u connect a 12inch sub without an amp? is it as easy as spliting the back speaker and wiring it up
    not really, u can but u`ll get **** all
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
      And how will you power it if not using an amp...? The subs need amps!
      Renault Megane...the OEM look
        you can, but you wouldn't hear much and you could overload your h/u if your impedance is too low
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          technically: yes
          good idea: no
            I doubt you could hear anything...I must say I've never tried...
              tried it once out of curiosity, get a little bit of sound...whisper quiet, but could feel the driver getting a tiny tiny bit of movement.
                if you try running a subwoofer off a HeadUnit you will most likely get sound that equals to about the same output of a good pair of headphones
                  I've done it too, I didnt have back speakers at the time so i hooked up two 8" MTX truck wedges and they we okay at best, no boom boom. I tried my luck with 4 subs for the rear to channel and it overloaded the h/u. Get an amp for $100 bucks at your local market and 20$ install kit at Walmart.
