Will this wiring diagram work? Suggestions?
  • Will this wiring diagram work? Suggestions?
    First of, I am not Dilbert so that’s why I need a little help.
    Description of “diagram”:
    The head unit powers up when I turn the ignition, the idea is to “piggyback” off this wire to a relay that will switch on the power to the lcd-screen and laptop.
    Does this look about right?
    Is there something missing in this diagram?
    I will wire a manual switch to turn on and off(hibernate) the laptop.
    Jeg går litt tidligere i dag, så kommer jeg heller litt senere i morgen!
    VW 1999 Passat fabrication
    Looks good to me. A little simplistic, but a proven classic.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
      looking good, that should work fine
      nice diagram btw
        Thanks for quick response!
          Do you mean you will wire the on/off switch to the power button on the laptop? Otherwise, it won't start without you hitting the power button separately.
          Want to:
            Yes, that is the plan!
            Cracked open the laptop yesterday, and found the where to connect the wire. Will hopefully solder it today!
            Want the button, so i may restart it without going to the trunk, or restart the car.
            Maybe later i'll fix it to start with the engine!
