Setup Help
  • Setup Help
    I'm still waiting for the rest of my setup to come in the mail, but for now I have the motherboard, psu, and screen, and I just wanted to play around with it so I grabbed a spare harddrive and dvd rom. I'm using a epia m10000 board and I'm trying to setup windows on the hd, the bios screen loads fine but it won't boot to the windows setup at all. This is my first time ever building a computer so I have no idea if I'm missing a step or something, the bios is setup to boot from the dvd drive first so I don't know what else to do, please help me.
    my setup - finally
    http://www.mp3car.com/vbulletin/showthread.php?t=50494
    Does it try to boot from the CD-Rom ? Do you see any flashing light coming from the CD-Rom drive when the bios is starting ? To enter Windows XP setup, it should be written something like:
    Booting from CD-ROM:
    Press any key to enter setup...
    for about 3seconds. Then if you press a key you'll enter the setup.
    Do you get any error message ?
    Do you have an original Windows CD ? Some copied CDs might not have a boot sector on them..
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
      its a copy, is there any way to get the boot sector on a copy
      my setup - finally
        if your using the lcd touchscreen, you need to set it up in the bios first for it to work past the bios screen, at least i had to for my setup, m1000 epia, lilliput combo
        CarPuter ProgressO meterO
        [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
        visit me on the web at
        http://gozips.uakron.edu/~cmk23/
          Did you go in the bios and make your primary boot device the cd-rom?
          Edit: Oh yeah, I forgot, to change the boot device, you need to go in your bios setup (press delete or the button it tells you when your at the black screen when you boot your computer).
          Than you go in Advance BIOS Features(or something like this) (2nd or third on the left).
          Than look for First/Second/Third Boot other device, or Primary Boot device, or something similar.
          Than choose the cd-rom drive (should be d: since you have one hard drive, could be something else, like e: or f: etc...)
          After That go back to the start and do save and exit.
          Last of all, Its gonna ask you if you want to boot from the cd-room, press enter or space or any other button. Setup starts after this.
            Make sure the burnt cd works on another system. If it does use that CD Drive to load Windows. I'm pretty sure its the CD and/or Drive that is causing the problem.
            1994 Acura Integra GSR (Bone Stock)
            Alpine CVA-1005
            Alpine DVA-5205
            Dreamcast - MP3, MPEG and Games
            JBL DA1002-90
            10" Soundstream Tarantula T2-10
            Wiring by neema12
              on my normal computer it doesn't load to the windows setup either, but I know I've used it before and its worked, but this is a different copy of the disk. is there any file that should be on there to make it load from the start?
              my setup - finally
                I have the same problem with my cds. It will work max two times then it'll stop working. I just reburn the original and it should work again.
                Alpine CVA-1005
                Alpine DVA-5205
                JBL DA1002-90
                Wiring by neema12
                  the original is about 1250 miles from here, i had my bro just put the contents of it in a rar file and send it to me then i made a cd from it, guess ill have to have him mail the original
                  my setup - finally
                    You could actually purchase the software...
                    Want to:
                      you will need the boot floppies for XP if your disk doesnt boot itself. Theres a program you can download and run to make them, its on the M$ site somewhere (and elsewhere- maybe bootdisk.com), you need 6 blank floppies. or you can use a win98 boot disk but with smartdrv added to it- probably easier to get the set of 6
                        yeah. you are pretty much screwed. only thing i can suggest is to *cough* download a proper iso *cough* of it. they usually include the boot sector so it will boot correctly.
                        Your everyday carpc geek and tech guru at your service. *bow*
                          www.linuxiso.org
                          Alpine CVA-1005
                          Alpine DVA-5205
                          JBL DA1002-90
                          Wiring by neema12
