Install help!!!!
  • Install help!!!!
    im having the setup from hell. this is on an m10000 board. ok, ive reset the bios numerous times, in the bios setup it shows the harddrive on the primary master, the dvd drive on the secondary master. when i try to load windows it goes through the initial blue screen setup and then instead of rebooting to windows to finish the install it boots back to the initial loading screen. it is an original xp disk, this happens regardless of whether i have the cd drive to boot first or not, the only things connected are the motherboard, ram, psu, dvd drive, harddrive, keyboad, mouse and monitor. with my other harddrive i had gtten all the way through the windows install but then it stopped recognizing that harddrive so i got a new one. does anyone have any idea whats going on here, did i screw something up? im going insane here
    my setup - finally
    http://www.mp3car.com/vbulletin/showthread.php?t=50494
    Try removing any jumpers from both your harddrive and dvd-drive.
    ODYSSEY
    Originally posted by Tidder
    Digital-Car UK|
    (\__/)
    (")_(")
      i just want to say thank you very much, this was driving me nuts for the past two days. i removed the jumper from the harddrive and the bios no longer hung and everything went completely smooth, it was like a new computer. i don't understand why that would cause that, it was set to master
      my setup - finally
