Front end for streets and trips
  • Front end for streets and trips
    Hi All
    Is there anything out there that will work with streets and trips as a front end, or use maps from it... or whatever, but just inshort make streets and trips a functional navigation tool.
    All those that have used streets and trips know that its not very functional as a navigation tool, it more like a mapquest installed on a pc.
    pls help
    04 Corolla
    Upgrading pc 99%
    And you're right. S&T is garbage for navagation.
    iGuidance. Routis. Destinator (and variants). CoPilot (if you can afford it). Theyr'e all good packages for navigation.
    How about the Wiki?
      I am working on something, I have 4 years of maps in MS Streets (now S&T2005) and would prefer not to start over. It is not the greatest for entering data but it gets me where I am going pretty well for the most part. I usually use it to build complex routes (for the driving enjoyment, not point A to point B) in the house and then transfer it to the car so it works well for that.
      I would like to make a RR skin to run the thing but have not had time to play with it. I am fairly new to this kind of stuff so I am not totally sure it is possible.
      Currently I am using a Powermate with the following settings:
      right = + (zoom in)
      left = - (zoom out)
      click = Nav pane
      long click = GPS pane
      down right = tab
      down left = unassigned
