Renault Megane Ideas please?
  • Renault Megane Ideas please?
    Hello, Im new to the forum and i am going to be putting a PC in my renault megane II.
    Can anyone who has pics of a Renault megane Installs please post them so that i can get some ideas?
    So far what i have thought of doing is using the Megane CC Screen Click here for the Screen and pluggin in my own computer for the sat Nav, Mp3's Etc....
    I would also like to see some other ideas that people have and have already done?
    Cheers
    Neil
    Neil,
    I am also installing into a 2004 Megane II sport saloon. I have at this stage chosen to place my Lilliput 7” Touch screen on a home made slide beneath the standard radio. If you remove the tray unit under the radio (assuming you don’t have the factory fit 6 CD changer) you will find another standard din opening. I have filed away the bottom two sides to allow the Lilliput to fit within. If I was to do it all again I would get a motorized VGA monitor and put up with the expensive.
    The Megane's a very light car and you will have problems with reflections on any screen you put in.
    The audio I have eventually had to purchase the Connects2 VRNX001 @ £55.00 after trying FM modulators etc. The sound's very good and it allows the volume +/- , mute from the steering controls. This unit fits all Renault radios with the word ‘Tuner List’ on the front. Lift out your radio and you should see a blue connector where the cd changer connects.
    Ill post some pic’s once I get time.
    Les
    Compaq EN SFF, P3 450Mhz pc
    M1-ATX psu
    Windows XP pro
    GPS - Globalsat BU303 GPS Mouse − USB
    GPS software – MapMonkey
    Software front end – MediaCruiser - modified
    Car: Megane II Sport
    PC: Compaq Deskpro EN SFF P3 450Mhz
    PSU: M1-ATX PSU
    MONITOR: Lilliput 7" TS
    WiFi: 56g WIFi USB
    GPS: BU303 GPS
    AUDIO: VRNX001
    FRONTEND: AshInCar
    SATNAV: MapMonkey & D3
    OS: XP Pro
      Thanks for the pictures! I'm considering the same Connects2 interface to replace the stock 6 cd changer under my Clio's driver seat. I have a few questions:
      If you switch to the cd changer with the stalk control, how does the interface behave? I mean, what happens if you try to select different cds or different tracks (all of which of course makes no sense). What is shown on the display during operation?
      Is the interface just a black box or does it have any user configurable options (jumpers, dipswitches)? I assume it comes with a cable that plugs into the blue connector on the head unit. How long is the cable? Actually I'd rather put the interface under the chair, cause the wiring is already present and the carputer will be mounted there as well.
      CarPC status: HW all done, SW needs tweaked.
      Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
      Software: RR, MM/FD
        The Megane has a very friendly dash for a screen! It fits awesome in place of the stereo and the tray bellow it. It's also easy to fabricate. As for the sound, get an amp, and control the sound and other stuff through the steering wheel controls. The only downside to this is that the upper display won't show anything else but the outside temp, but that's a fair enough casualty. Also, that stock nav screen is way to small.
        Renault Megane...the OEM look
          Mox,
          The VRNX001 adaptor is simply a device to fool your radio a CD changer is inplace to allow the aux input to pass through. The box has no jumpers to set and in the pictures you will see theres a lot of electronics for what it does. In operation when you use the steering source selection it cycles through to you CD then to a second CD1. I understand this is the same as if a cd changer was connected. The track change when on CD1 has no efect.
          The box come's with a short connector to the head unit approx 12" in length. It also comes with a stereo 3.5mm jack to two phono RCA connectors to allow you to plug-in a MP3 player or other audio device with headphone jack. This lead is approx 24" in length.
          Regards
          Les
          PSU: M1-ATX PSU
          WiFi: 56g WIFi USB
          GPS: BU303 GPS
          AUDIO: VRNX001
          FRONTEND: AshInCar
          OS: XP Pro
            Thanks for the info, I think I'll order one. My experience with inline FM modulators has just been awful!
            Software: RR, MM/FD
              Thanks for all your replys, Some great info there! Has anyone got any pics of there installs as i want to see what they look like before taking my dash appart?
              Also what PC's are you using in the background of the install...
                See my sig
                In case you will be keeping your OEM head unit, I can recommend the VRNX001 aux interface from Connects2. I popped mine open and did some reverse engineering on the circuit board. It's a nifty piece of electronics. Worth every buck.
                The OEM Renault VDO "Tuner List" HU's don't have an analog line input, not even for the external cd changer. Instead, the HU requires a digital SPDIF audio source. Therefore, the purpose of the Connects2 interface is not only to fool the HU into believing that a cd changer is connected (which in turn will activate the external audio input), but it also contains an A/D converter to convert the analog audio source to SPDIF.
                It might be possible to even further improve signal quality by hooking up the HU's SPDIF input directly to the mainboard's SPDIF output. The RCA connector at the back of many (if not all) VIA mini-ITX mainboards can be configured to output SPDIF instead of TV-out. This will also eliminate ground loop noise. The "fooling" circuitry of the Connects2 interface will still be necessary of course, otherwise the HU's SPDIF input won't be enabled.
                I haven't tested all of this yet, but I will post pin assignments of the blue 8 pin mini-ISO connector when I get home.
                Software: RR, MM/FD
                  More info in this thread: http://www.mp3car.com/vbulletin/showthread.php?t=53347
                  Software: RR, MM/FD
