Bottom of desktop cut off at 800x600
  • Bottom of desktop cut off at 800x600
    Basically when I set my screen to 800x600 via windows, the bottom third is cut off and unaccessable. Xenarc detects it as 800x480. Whats the easiest way to fix this?
    MII1200 video
    Check the frequency the graphics card is pushing out to the screen in display properties, Settings, advanced.
      60hz in the display properties....xenarc also says 60hz
        Try it at 75Hz and see if it makes any difference.
          Yes same here like uk mp3car said just change the refresh to 75hz and it will fix the problem
          RexBruMet Skin for FrodoPlayer
          Nissan Aux-in MOD
          Originally posted by bgoodman
          We're an international forum, post in whatever langauge you like.
            did the trick...thanks guys
