Monitor fabrication quues
  • Monitor fabrication quues
    Hi there, I got the replacement radio facia and cut it up a little to have the screen in the position i'd prefer.
    I'm now needing to fill in the space around, which is the best way to do this?
    I also wouldn't mind recessing the screen or something. Or creating a shutter or something to hide the screen.
    please help, thanks
    2003 Volvo S40
    lilliput 7" touchscreen
    Epia MII12000 mobo
    512 mb RAM
    Opus 150 PSU.
    Slimline DVD
    Follow the link in my signature to the FAQ Emporium. There is a link in there on "How to install your monitor".
    Want to:
      Thanks for that...
      for the filler did you use car body filler with fiberglass?
      2003 Volvo S40
      Epia MII12000 mobo
      512 mb RAM
      Opus 150 PSU.
      Slimline DVD
        It wasn't me, it was Alti. But most people use Bondo for the small stuff, fiberglass bondo for bigger stuff.
        Want to:
          Omfg That Is Sucha Clean Look!!! A Bit Of Bondo And Sanding And Your Good To Go Damnnnnn!!!!
            oh yeah u can also send it to me nad i can fab it for u pm me for more info!
              Thanks xdjxklusivex but you are based in the states whereas i'm over the pond in the UK. also i wanted to have a crack at it myself...
              By Bondo do you mean body filler?
              2003 Volvo S40
              Epia MII12000 mobo
              512 mb RAM
              Opus 150 PSU.
              Slimline DVD
                just normal body filler, but use the flexible stuff for best results, i also used small bits of perspex on the larger holes to add abit more rigidity to it. Also when you prime use filler primmer as that helps cover up the little blemishes that are left after sanding. good luck with your project
                  Thanks for clearing that one up ste!
                  However i've been reading about this abs cement and it seems a better option....
                  I'll keep posted!
                  2003 Volvo S40
                  Epia MII12000 mobo
                  512 mb RAM
                  Opus 150 PSU.
                  Slimline DVD
                    featherweight is the best for stuff like that. As Altimat mentioned the evercoat stuff is awsome, but you do not have much work time, 5 minutes tops. But then you can just sand it down and go at it again. The stuff sands brillantly.
                    My Install
                    Software:
                    CFiG v1
                    iGuidance Plugin for CF
                    CarShell
                    Working shell for a CarPC
                    StopWatch
                    StopWatch plugin remade for centrafuse RC1
                      How are you securing the Lilliput in mate?
                      Ice: Nakamichi MB100, Dynaudio 340, Genesis Dual Mono, JL 12w2, Epic 160
                      Current Project: Fitting a Cologne V6 to an Eagle SS
