I cant get sound out of RR
  • I cant get sound out of RR
    HOw do i get winamp to play my music on RR.....thnx..I've searched on the front end forums but could not find an answer....
    ermmm press play ....
    Make sure the path is setup in rrconfig to both winamp and oyur music folder
      tnx but winamp appears is this normal...i check to hide winamp but it still comes
        No that is that normal if Winamp is in front of RR and you checked hide. Also, make sure you have your music path correctly in the RRConfig file.
        Its not the cards you're dealt, its how you play the hand!
        Originally posted by ryuandwings
        Where can I get a roll of tin foil?
        I been looking for that all over the net, but I can't find it.
        Please help.
          Does any music appear to be playing (postition bar move or timers counting up/down)?
          (BTW, you'd probably get better help with this over in the RoadRunner forum.)
          Progress [||-------]
          View my Worklog to see some of my progress.
          Downgraded Progress - Starting with another car... 09/13/06
            -Make sure you have a NON-Lite winamp version
            -Make sure you don't have "always on top" set in winamp
            -Make sure you're using a CLASSIC skin
            -Make sure your winamp path is set correctly
            -Make sure your music path is set correctly
            -Load files in winamp (using the audio browser in RR)
            Read the Install FAQ on RR's subforum.
            Ride Runner RR's Myspace
              - check the page with the mixer in RR (the crossed hammer n spanner symbol) and make sure the levels are up
