Turning on an amp without a headunit. . how?
  • Turning on an amp without a headunit. . how?
    Hi there
    Hooking up an amp to a carputer. problem is that the head unit which is SUPPOSED to be hooked to the amps is what tells the amps to turn on in the first place. any thoughts on how i can manually turn on the amps at any given time? maybe with say a switch of sorts?
    Thanks for the help,
    ~N8r4d3
    Yes.
      wire remote switch to ignition switch
      badda bing
      [||||||||||||||||||||] - final touches
      SUPER 7" VGA w/ TS
      Toshiba Satellite 3000
      P3 850
      256MB
      30GB
      Geforce2 Go
      DVD
      Orinoco 802.11b PCMCIA
      nlite WinXP 350MB installed
      RoadRunner
      iGuidance 2.1
      Holux GM210 GPS
      Xantrex Xpower 300
        the remote wire is just a low wattage 12v feed.....so any 12v source thats either switched, or switched by the ignition will work
        PC Components:
        My work log
