Navigation problem
  • Navigation problem
    hello, i am new here so i could use some help!!
    i am using navigator 3 with map monkey and greek maps.
    while trying to navigate i am getting an error msg ""PATH NOT FOUND: INCORRECT BEGINNING LINE DIRECTION""
    The wird thing is that the first time i click "navigate" to a road, it works like a charm!
    If i try to navigate to another road then the error msg appears...
    you might try posting this in the designated form for your problem, I'd bet you would get an answer a lot quicker
    or even here for MapMonkey:
    Jan Bennett
