confused need help..
  • confused need help..
    hey all....
    im confused and need some help..
    how am i gonna power up my pc..? with a Inverters or opus? and what is best? if opus which one? this is my system a p4, 1 4chn amp 1chn momo amp and touchscreen.
    Unlikely a P4 will be powered by an Opus. First time I think I've said it but go read the Faq Emporium.
    James Radcliffe
    [email protected]
    Planning (Phase I)
    |||||++++++| 40% Making Final Pre-Purchase Plans
    Car Stereo (Phase II)
    |||||||||++| 80% - Building box, getting ready to wire
    Carputer (Phase III)
    ||+++++++++| 10% Desiging CarPC case
      i have read the FAQ...
      some say that the inverter could be dangerous others say not..
      adn the inverter is bigger that the opus.. but the problem whit opus is that the opus output is only 150wat i dont think that is enough, because there is a small label at bag side of my pc case and it says 230...
        do you really need a p4 for your car? just for music/movies/gps right? you can do that with waaaay less than a p4
          Get two!
          Laidback
          The ultimate CarPC - Wow!
            [email protected] 60% = 138w ... you might just get away with it if you dont overload it with other high ampage kit like 3.5" hdds or cdroms (use 2.5" stuff instead).
            You really need to test it for ampage draw to confirm it, overall standard ATX kit is way inefficient (even with PFC) and the opus is very efficient. Test it, or get one opus for the mobo and a 90w for all the other bits.
              Thanks MAD AD...
              this is what im thing of the pc:
              a intel p4
              7" widescreen with touch
              slim hdd
              slim dvd
              usb gps.
              soundcard 5.1
              i dont now if im gonna use the onbord grafik card or buy one..
              2 amp 1 for the speakers and 1 mono for the sub's
              and how im a gonna connect the amps from the digital in/output??
              how am i gonna connect the 2 amp with only 1 digital output from the soundcard
              with opus 150 do the job?
                will this do the job
                200W
