what size inveter should i use for this setup
  • what size inveter should i use for this setup
    ok my plan is to put a pc in a car.. <duh>
    a p4 cpu , and somehow connect a laptop screen to it<not sure how yet> and add a 5.1 speaker system...
    now i am not sure how much power they need ... here on the normal its 240v
    not sure how many wats the cpu might consume but having a problem figuring out the 5.1 speakers it says power output 55W i guess that is it...or? it also says p.m.p.o 5000W
    slow down geezer!
    first thing is make a list of everything in your system and set yourself a PSU power.
    Then mulitply this by 1.5 and that is your inverter.
    As for speakers.....are you wanting to use some home PC 5.1 speaker sin your car? So you want to run them off an inverter too?
    As for the laptop screen - don't bother - it will cost you more than buying a VGA screen as you will have to get some kind of controller - and you shall see why.
    Also dont forget you will need some kind of startup/shutdown controller and to be honest i would reccomend a DC-DC solution over an inverter. If you are careful and dont get too greedy with the P4 spec and dont use lots of 12V devices (5.25" optical drives, multiple 3.5" HDDs etc etc) then something like the Opus 150W will do you or you can wait for the new higher power models while you get on with building your system.
      psu.. sorry not too electrically inclined
      yes i was actually thinking of usin pc 5.1 speakers
      can u fill me in on startup/shutdown controlers as in how or why they are needed. i really doubt the opus... i live in ghana west africa and stuff isnt exactly easy to come by.. i am sure u catch my drift...
      waiting for ur reply.
        PSU = power supply unit = what powers your PC!
        domestic 5.1 speakers in a car - hmmm not sure about that. I suspect the amplifier you get with them will pick up a lot of noise from the car electrics.
        startup- shutdown controller - you are best going and reading the FAQ's as everything will be there and i might miss something as I am in a rush.
          would there be any way to reduce the noise the amp will pick up?
            do not run a 5.1 sound in your car, ew. just hook it up to your car stereo.
              y shouldnt i run 5.1 in my car? i can add the speakers in the car and get 9.1
                because home speakers sound worthless and youd be gettin in too deep trying to add them in, just use car audio...after all look at the name CAR audio.
                  omg i cant believe it...scouse actually helped someone and didnt whore in this thread! too bad i cant say the same for myself lol
                  i got dat ***** sittin on 22s! SUPERMAN EDITION!
                    Startup/shutdown are ok if they are needed, i would drather have control of the power myself.. I dont always run my carputer, i know where the store down the street is, and sometimes setting up navigation takes longer that actully driving there. I run a switch controlling a relay, which controls the dc/dc converter in the destop in the trunk. You dont want to run a switch controlling a large amount by itself, let the relay do that and the switch to control the relay.
                    If your laptop or desktop already has 5.1, go ahead and run that thru amps into the rest of the car... but if you're like me and not going to have the cpu on every waking moment of the car's life, you're going to miss listening to the sounds unless you have your sound system independent of your carputer, then in that case, dont go 5.1, go regular car stereo with an aux in, or a regular car stereo with a FM transmitter configured to a blank freq on the radio (thats how i do it).
                    For every decision, there's another 100 decisions to be made...
                    Sit down and plan what you want. then figure the cost. then go from there, this is definetly something that is not done over night.
                    Hell, I dont think i have ever seen where someone has actually completed their project.. Have fun and don't go nutz
                    Dual Lilliput's 70NP/C/T
                    Syntax SV266AD KT266A
                    AMD Athlon XP 2000
                    Viking 256MB DDR
                    D-Link Wireless 802.11B
                    Seagate 120GB
                    OrbitMicro 250W DC/DC converter
                    SII Wireless Audio Link
                    Digimoto OBD-II
                    Earthmate GPS
                    BU-303 USB GPS
                    D-Link Bluetooth
                      suck my balls EsKalad!
                        The mpegbox DSATX 220 Watt DC-DCs are in stock and shipping now. I just got mine.
                        GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
                        Worklog: http://www.mp3car.com/vbulletin/showthread.php?t=65059
                        Now with pictures!
                          already have 5.1
                          well i already have a 5.1 in my desktop... but to run it through amps is what i dont follow... my 5.1 is a desktop speaker system... all wiring go to the sub so i believe there is an amp already in there... or?
                            What MB and sound card (if its not on the mb) do you have? You might have said before but i cant find it.
                            Are you planning on running the carputer as the only source of music?
                            AMD Athlon XP 2000
                            Viking 256MB DDR
                            Seagate 120GB
                            Digimoto OBD-II
                            Earthmate GPS
                            BU-303 USB GPS
                            D-Link Bluetooth
                              dont remember the brand of the mother board but i know its a p3.. cant remember the other specs but i know they are enough to work with for now.. the sound card is creative live.. its for 5.1 speaker system....
                              i still have my stock radio... i was thinking of hooking up its speakers so when i feel like using all the speakers including the cars orignal speakers i can...
