Headless solution / carputer as head unit?
  • Headless solution / carputer as head unit?
    I recently promised to set up a carputer in a friend's Jeep Cherokee (late 1980s). He buys the parts, I do the labor for free. Catch is, I've never done this before, and have only worked with desktop computers and the occasional laptop before.
    This project began earlier today when he conveyed that the faceplate for his Sony Xplod head unit had been stolen and the unit is now useless. I made the suggestion he replace the HU with something a bit more homebrew, and after some persuasion, we (well, mostly I) started making plans. The system will consist of a computer running Linux mounted behind the rear seat, and a custom-made interface filling the HU socket in the dashboard, consisting of an LCD display, some buttons, and a slot-load CD-ROM in a homebrew enclosure, possibly built from the casing of his old HU. (VERY custom job, in other words.)
    I still have a few kinks in my design:
    As far as I've seen, nobody's actually tried to use a computer as a HU before, only connected it to their HUs which then manage the speakers and handle volume control. Has anyone ever replaced their HU with a computer? What extra steps/equipment was necessary?
    I'm not sure how the buttons will interface with the computer. Is there a nice USB package to do this perchance? What have people used for buttons in their setups?
    For controlling the CD-ROM, I'm leaning towards gutting a USB enclosure and using the electronics from it. I'm not sure how to power the CD-ROM though. It needs a 12v line, which the USB connection can't provide. (There's a 200mA limit anyway, not enough to power a CD-ROM drive by any stretch.) Should I run power wires from inside the computer across the truck to the dashboard, or hack up the enclosure's amp to run off the car battery (if possible)? Will the chipset misbehave if it's not receiving power except via USB?
    As for the dashboard unit itself, I intend on building the unit by hand, but I don't know exactly how to do this. I've heard talk about fiberglass and something called "bondo", but don't really know what it means or how to use it / where to get it. Being a desktop computer technician by trade with no taste in aesthetics, I've never done as much as case modding before. How should I approach making this dash unit?
    I was looking at using the Opus 150W power supply; however it's a tad expensive and driving up the unit price in a big way. I'm running on a tight budget ($500 for parts for dash interface, computer, and everything else) so $160+ hurts. Is there anything else that's reliable but still car-safe that I can fit in a Micro ATX case?
    He's had numerous problems with theft before (in fact, that's how this whole project started), so is there any way I could mount the computer into the truck so it can't easily be removed? Same for the dash unit.
    For cheap power I would suggest a desktop power supply (200 -300 watts) and an inverter. Inverters cost about $20 for a 225 watt and $30 for a 400 watt. You will also need to setup a startup and shut down controler to allow the computer to start when the car is started and to allow it to safly shut down when the car is off so it does not drain the battery. (http://www.mp3car.com/vbulletin/show...3&postcount=21)
    I would suggest running the cd rom and lcd off of the regulated 12v and 5v lines of the power supply, that way they start with the computer and provides regulated current for longer life.
    For audio you will need a 4 ch amp and possibly a subwoofer amp. You will need a front and rear output on the motherboards onboard sound or a 5.1 sound card. You can in a pinch use the single speaker out on a motherboard if you split the jack into two and use two headphone jack to rca converters which would plug into the 4ch amp. The amps remote turn on would require you to run a +12v line from the computers power supplie to the remote lead on the amp. So it will turn on with the computer.
    You may also need a fm tunner card if your friend would like to be able to listen to the radio.( since he will no longer have a head unit.)
    As for the lcd a 7 or 8 inch touch screen monitor would be ideal and that could be run off his computer 12volt line on his power supply.
    You many also want to consider installing a usb hub in the front of the car to allow for usb devices like a keyboard and mouse. If you are planning on running a usb hard drive or cd rom you should use a powered usb hub. This requires you to run a 5 volt line from the power supply to power that and allow it to support usb powered devices.
    Hope this helps.
      As for the thieft issue if he has a rear spare tire well you can possibly make a floor out of mdf and create a trap door in it to access the computer. This would allow you to put a latch and a lock if you desired. Or you can bolt the computer case to the floor of the jeep or to the seat brackets. Just a few opinions
        FWIW: He just informed me his Cherokee is a 1989.
        I'd like to avoid the inverter solution if I can. I just have a hunch. I'm right now thinking about getting an M1-ATX and modding a mounting place for it into the top of the case (which shouldn't be TOO hard, as there's a sizable cavity for the power supply in the case I'm looking at).
        Regulated! I didn't think about that. Thanks, I'll keep it in mind.
        On a similar note, do you know if anyone's successfully used the guts of a USB enclosure in a carputer setup? I'm not sure if it's all that easy without resorting to an inverter, as it may rely on that external power somehow, but here's hoping.
        I have a spare 4-channel card laying around, I think I'll use it. Thanks!
        Oh yeah! Oops.
        We decided that a proper LCD screen would just cost too much for this project. The cheaper the better, as long as it's going to last without costing maintenance for a while. I'm going with an interface that looks and feels like a head unit face.
        Again, excellent idea. Takes some load off the motherboard power-wise as well. Thanks!
        I'm still stuck on how to craft the dashboard unit though. As I said, an LCD monitor is just too much, and I'm looking for a homebrew interface with buttons and an embedded LCD display similar to what Crystalfontz offers. Putting it all together and giving it a shape though, I'm not sure how to approach it.
          Originally posted by roothorick
          ....As far as I've seen, nobody's actually tried to use a computer as a HU before, only connected it to their HUs which then manage the speakers and handle volume control. Has anyone ever replaced their HU with a computer? What extra steps/equipment was necessary?
          dude, there are plenty of carputers on here that are headless, the carputer is there "head unit"...... this is quite common actually
          search for girder or x-keys for all your button interface stuff...
          the "gutts" of a usb enclosure for the cd rom is nothing more than a usb/ide converter.... can be had with or without an enclosure..........
          all the answers are out there, just search..........
            You have some good knowledge, very good for someone that jsut thought about it today! definitely above average!
            Anyways, everything you talk about has been done, so there you are underestimating the community/oversetimating yourself.... Everything has been thought about/done before So my advice would be go into the Show your Project forum and check some jeep installs, etc...
            Roy
            2005 Range Rover 4.4
              Yeah, and for God sakes man....add the car alarm to the budget!!
                most of the carputer setups here don't use headunits. their soundcards are connected directly to the amps.
                Brushed Metal for Centrafuse 1.4
                Brushed Aluminum for Centrafuse 1.4
                xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
                  my father used to have an 89 there should be a nice place for the computer under the rear seat. also maybe built into the spae tire rack on the left side. good luck
                  .______
                  | '_ |__\___
                  [(o)|___(o)] XB
                  ._________
                  | I__I I_I|_\__I
                  [(o)______(o)]b VanPimpin'
                  LostReceptions Apps D/L Here
                  GPSGasoline- Rewriting
                  CarPCNetwork
                    I hate to revive an old thread but I've never worked with car audio equipment before, and would like to know what I'm doing instead of making costly and stupid mistakes.
                    Do most cars' factory configurations already have amps besides whatever the head unit may have? More importantly, does the Jeep in question already have the amp(s) I need or do I have to get one?
                    Where can I find a wiring diagram for this truck? Google has failed me...
                      5 days isnt an old thread here, but i digress.
                      I don't believe the jeep had amps from the factory. Most cars don't.
                      As far as wiring diagrams, tell your friend to go to autozone and get the haynes manual for his jeep. You NEED it to do this install. It will tell you how to remove the radio, seats, trim, console, door panels, speakers, everything. Wiring diagrams will be in there, but since the wires will all be bound with 16 year old electrical tape, good luck finding the wires you are looking for. My advice is to get the headunit connector for that jeep and run your wires through it. The piece I am talking about will let you connect an aftermarket stereo to the factory wiring harness. Your local car audio shop should have it for, say, $15.
                      Oh, and most common car audio newbie mistake: Running the power and signal cables right next to each other. Run power down one side, signal down the other.
                      Debt as of 1/1/05: $34,354.48
                      Debt as of July 4, 2007: $0.00 explanation
                      I'M DEBT FREE!!
                      I'm now a reasonably successful gunblogger.
                        Okay, Go to www.the12volt.com for your wiring needs. You need to register but then its free. (seems to be down at the moment) There are more out there just google. No one else said it so i will. You might consider a EQ Pre amp. It would have a volume control and would only need stereo input from the computer. Most of them would then give out front rear and sub.
                        I dont like the idea of the volume only being controlled through the computer. Even at home my speaker system has a seperate control for volume. And i think most EQ's have a remote out on them that could be connected to your amps. You might not want.......never mind you said no lcd. I was going to say have IE up or GPS running you might not want the amp on. But since you have no LCD
                        Option 2: External usb audio box with volume control on it. Mount it in the dash. =)
                        Um, I guess this is where you put something witty.WITTY
                        My Web site, in the design stage. http://home.comcast.net/~cstrachn
                        Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
                          In that case, do I really need an amp in the first place? As I've said before, I've never worked with car audio equipment, my experience with electronics lies almost entirely with desktop PCs and some server hardware.
                          I'll ask him about the manual. He's already gone through two or three aftermarket head units, so I think he already has the connector.
                          I haven't made wiring plans yet (being my lazy self), but I'll keep that in mind. About how far apart should I keep the two? 3-5 inches? A couple feet?
                            Yes you need an amp the output from a sound card will not power car speakers
                              Welp, I have a pretty thorough plan, and for once in my life I have something that I think will work. There's still just one last thing to take care of.
                              Instead of an LCD display, I'm opting for an in-dash unit resembling a (factory or retail) head unit. It'll have a small LCD character display (I'm looking at some Crystalfontz units) and a set of buttons, and a (slot-load) CD-ROM drive for reading and ripping audio CDs and "MP3 CDs". The only question is how I'm going to make the front of this in-dash unit. I saw one reference to fiberglas, but it didn't go into details. Has anyone made a custom faceplate for their HU or anything similar to this before?
