CarPC instalation?!
  • CarPC instalation?!
    Helo, I made a setup for my system, does this is safe? and wil everything work?
    I put my screen direct on accu because I'm afraid 90W won't enough
    The mobo is MiniITX, The HDD is slimline.
    Thx! Suggests?!
    Thx! Suggests?!
    If your installation skills are even marginally better than your artistic skills, you'll be fine.
    How about the Wiki?
      It was drawn in a hurry sorry
      but is this working? and safe?
        I have my touchscreen plug directly to my cigerette socket. as long as you have a fuse in there, you should be fine... been running for over 2 years without a problem.
          isn't there something that I can put in place of te fuses?
            Nothing that would perform the same function.
            You want a fuse there so that in case of a power overload the fuse will blow and not your expensive equipment.
            How about the Wiki?
              You could put a fire extinguisher there instead of the fuse.
              iGMon - Integration between iGuidance and Road Runner
              CFX - Skin for Road Runner
                So my draw is perfect? what can I do to make it more safer for burning?
                Can I put my pc in hibernate for 24hours? without lossin' accu?
