Restarts insteading of turning off
  • Restarts insteading of turning off
    Hi Guys
    Wired up my carputer. Before I installed windows XP on it I am positive it was turning on and off with the ignition of the car.
    Now I installed windows XP and when I turn the ignition off the pc switches off, but then turns back on again when it should stay off !?!
    Can someone explain why ?
    Car is wired up with a http://linitx.com/product_info.php?c...roducts_id=598 psu and should work with the ignition
    cheers
    Which powering on/off scheme have you set your M1-ATX on?
    Also, what kind of scheme do you use on the Power Buttons setting on the Display Properties?
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
      Sounds like you have the power button set to restart the computer in your XP power scheme setting or you hooked it up to the reset pins instead of the pwr button
      Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
