usb 2.0 conversion
  • usb 2.0 conversion
    is there anyway to turn a usb 1.1 into a usb 2.0 on a motherboard that has no pci slots? thanks for the help
    If your mobo is USB 2.0 compliant than most likeley an Update to SP1 or 2 with Windows XP will do the trick...
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
      maybe if you're a good EE, but you can buy a usb 2.0 board for $35 or less on ebay, depending on your proc
      Shawn
      Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
        If the circuts are 1.1 then no you cannot.
        TruckinMP3
        Read the FAQ!
          so there is no way i can change it to usb 2.0. the reason is that i want to hook up a rear vie camera through a external tv tuner and i want the best quality i can get so i wanted to upgrade to usb 2.0.
            First off, as mentioned, it depends on the specs of your motherboard. Read the documentation. My motherboard only required windows service pack 1 to obtain usb 2.0.
            Second, it isn't really necessary for that particular application, unless the usb device calls for 2.0. The quality will be dependant on the camera itself and the capture card I guess.
            Carputer status: [-*---------]
            Im thinking laptop...
              yes the capture card needs a 2.0
