power supply issue
  • power supply issue
    can i use M1-ATX 90 Watt - Smart Automotive Power Supply with the CarPC Pro v.2.4 - The Most Advanced ATX Power Controller or is that over kill cause dont they share some of the same features. so...... then shouldn't i just get the Snap-On Miniature 12v DC Power Supply - 200w
    the M1 will do everything you need. start up and shutdown
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
      Read this
      and this to find out why the 200 watt power supply, isn't.
      Want to:
        can i use this CarPC Pro v.2.4 - The Most Advanced ATX Power Controller only or will i need the M1-ATX 90 Watt - Smart Automotive Power Supply too cause if not then just the carpc pro would be nice
          oh and well i know i need a power supply so what would be the best with the CarPC Pro v.2.4
            You were just told that if you get the M1-ATX, you don't need the CarPC Pro.
            Why are you so intent on using the CarPC Pro? If you want to use that and a DC-DC power supply, look at a Keypower unit.
            How about the Wiki?
              If you want to use CarPC Pro, get the Keypower DC-DC PSU or an inverter and AC PSU.
              Or you can get an ALL-In-1 option. M1-ATX, Opus 150W, or the upcoming DSATX. All can be found in the forum's store.
              Y2K Accord Dell GX150
              EmoRebellion is a SCAMMER
                i was just wondeing i guess cause i really like all the features the CarPC offers and the M1-ATX doesn't
                  you do as you like, but for myt money the all-in-one solution has worked for me.. I love the m1-atx .. it just works.. and works well
                  Shawn
