Suggestions?
  • Suggestions?
    Just wondering what you guys would suggest I get for this set up as far as powering it is concerned. Thanks
    Ps2
    Sony 17" LCD linkhttp://hardware.earthweb.com/periphe...le.php/3390681
    small inverter from s video to VGA
    Thanks again.
    The only power connector information I found was "using an internal power supply instead of a notebook-PC-style external adapter", which strongly implys it expects mains voltage at the connector.
    1st option would be an inverter capable of supplying "a thrifty 45 watts of power"
    2nd option would be at your own risk (electric shock, warrenty etc) to open up the case and find out what the mains voltage is stepped down to. A possible pitfall could be the backlight might simply step up the voltage from the mains.
    www.debthelpexpert.org
