RCA Aux Input Switch Toggle
  • RCA Aux Input Switch Toggle
    Hello everyone. Been searching the forums for an hour now trying to see if this has been mentioned.
    I have an Alpine HU with the RCA to AI-Net converter. I have an ipod and sirius radio I want to toggle between since I only have one AUX Input on my Alpine. I currently have my ipod and my sirius radio hooked up to this ugly switch I had for my tv. I know alpine makes a unit that switches between 2 RCAs and 2 CD Changers, but it's $149 for something I don't really need.
    Is there a better switch I can buy or make thats not as big and bulky as this solution? What I would like to do is put a toggle switch in my dash to switch between the two. Any pointers would be greatly appreciated.
    Thanks,
    MrMarbles.
    DPDT relay.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      Why not use a relay with your switch?
      I am going to put a 4PDT relay in a friend's car in the morning. Flipping one switch will throw the four signals (L+, L-, R+, R-) from either the XM or the aux input.
      CarPC #3: 99% Complete
      Pentium M 1.7Ghz, 1GB DDR2 RAM
      DVD/CD-RW installed in dash below monitor
      OEM LCD relocated for 7" Touchscreen
      Wi-Fi, GPS, PS2 controllers...
      500+ full albums
      4,000+ video games
      music videos, movies, & more!
      old carPC
        Thanks for the quick responses. I knew I could rely on a fellow matrix owner
        I hadn't even thought of a DPDT switch. Do the left/right RCA cables have + & - or are they just one cable?
          two rcas...both will have + and -
          If you strip the wire, the + is in the middle and the - is wrapped around it. They should be separated with a tubing like insulation.
          500+ full albums
          4,000+ video games
          old carPC
            How would I wire that up on at DPDT?
              You would have to have 2 DPDTs right? One for left, one for right? I'm guessing that's why you suggested the 4PDTs.
                I use DPDT and only switch the +s. The -s are usually tied to ground in each case. You should check this with a multimeter.
                  Yes, you should use 4PDT relay.
                  DPDT is how I get use to punch on the keyboard with my fingers, but I do mean 4PDT.
                    Thanks, I'll have to go searching around here for a 4PDT. BTW, MatrixPC, can I have your body kit?
                      2 Relays
                      you can build this with 2 single pole relays.
                      get 2 relay holders
                      1. attach both black wires to a good ground
                      2. attach both white wires to the same side of your toggle switch
                      3. connect the other side of the switch to a 12v fused source
                      4. label one realy "left channel" and the other "right channel"
                      5. connect the blue wire from the "right relay" to right + on your tuner
                      6. connect the blue wire from the "left relay" to left + on your tuner
                      7. connect the yellow wire from the "right relay" to right + on your xm tuner
                      8. connect the yellow wire from the "left relay" to left + on your xm tuner
                      9. connect the red wire from the "right relay" to right + on your ipod
                      10. connect the red wire from the "left relay" to left + on your ipod
                      11. connect left "-" wires together
                      12. connect right "-" wires together
                      OK your done. Fliping your toggle switch will now flip between 2 sources.
                      when theres power present to the relay, it will be on your xm tuner and when resting at ground it will defauldtto the Ipod.
                      E-mail if you have any questions
                        I picked up a 4PDT at Radio Shack yesterday...
                        500+ full albums
                        4,000+ video games
                        old carPC
                          What body kit? Mine came stock.
                            Your factory kit, mines a base, so no kit whatsoever
