American Megatrends (AMI) BIOS CMOS error
  • American Megatrends (AMI) BIOS CMOS error
    Hi... Does anyone knows where can i find this utility (AMIFL815.EXE)?!?!?!?
    I have a mobo matsonic ms7308et that does't save the settings and when i restart it hang up... but if i turn it off, it always says that the previous settings are rong (CMOS ERROR) and then i have to use always default settings... that means i can't for eg. change the boor seq. or turn off fdd boot... I already try to flash it using the utility available on matsonic site, and i did not find the utility on Amreic. Mega. Site...
    Help!!! Tnx
    Type the filename into Google and you'll get some results.
    How about the Wiki?
      i already try it... and i didn't have good results
        Try again. It's definitely there and very easy to find. I just did it and was able to click through to it from each of the first three hits.
        GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
        Now with pictures!
