Need Help Asap
  • Need Help Asap
    I have the SP13000 mobo it boots up fine until it gets to the windows logo screen, then it restarts. What could be causing this?
    Please help
    there could be a few problems
    it could be the memory or even the os
    do a memory test and reload the os
    once you have done that if still not fixed check your power supply
    http://www.customcarcomputers.co.uk
      There could be a lot of causes:
      Insufficient power
      Bad RAM
      Failing HDD
      Corrupt data
      Some more details about your system and the circumstances might help someone to do some actual troubleshooting. Simply saying that your motherboard freezes during Windows bootup doesn't give anyone anything to go on.
      How about the Wiki?
        Thanks for the reply.
        I have tried two hard drives. So maybe it it the power supply. I will try it in hte car and see what happen. the psu was one that I took off of my son pc to test with.
        It lets me get thourgh the bios, but when it tries to load windows it reboots. Maybe becuase it pulls more power?
          sp 13000 mobo
          512 400 ddr ram
          40gig 2.5 hard with 2.5 to 3.5 adapter
          thats all i have right now.
            As a last ditch attempt you can try reinstalling or recovering windows - if its a software problem this should fix it.
            Are you getting a BSOD before the reboot?
            '76 LR Series III 109 - Fully Sorted
            '95 Rover 620ti - Working on it
            A cynic is what an idealist calls a realist
              when booting try to boot to safe mode, press f5 right after the bios post and see if that works, if it will boot into safe mode then its a 3rd party software causing the problem. also what ver of windows you running?
              "There is No Spoon"
              Carputer:
              {lllllllll-} 90%
              7" Lilliput/120g Hard Drive/1g VIA EPIA/512m RAM/Slim Slot DVD+R/
              PC Done, Installing
              01 Z28, SLP CAI, DiabloSport Programmer
                Have you tried booting into safe mode?
                ATVMS.com
                  Just beat me with the suggestion of safe mode. BTW, you press F8 to get the boot options menu.
                  ATVMS.com
                    lol, but f5 boots straight to safe mode and bypasses the menu
                    "There is No Spoon"
                    Carputer:
                    {lllllllll-} 90%
                    PC Done, Installing
                      I can't believe I didn't know that one! I love keyboard shortcuts and faster ways of accessing things but didn't know that. Thanks for straightening me out.
                      ATVMS.com
                        I'm not sure but the M1K uses DDR266, and you are using DDR400. could this cause any problems??
                        Final Touches
                        Car: 2002 Mitsubishi Magna EI
                        CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
                        Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
                          He has the SP13000 which accepts DDR400.
                          ATVMS.com
                            I am using Window XP Pro.
                            BTW, what is the BSOD.
                            It will go throught the boot setup and the windows screen will show for about 1 sec and then reboot.
                            The same think happens in safe mode.
                              User operation
                              ODYSSEY
                              Originally posted by Tidder
                              Digital-Car UK|
                              (\__/)
                              (")_(")
