Damage to HD from subs?
  • Damage to HD from subs?
    I'm sure we all know that vibration is the enemy of harddrives, over time causing them to go corrupt... My question is, is there people that have had a moderate sub setup (like a solo 12") that has been running it for a good deal of time w/o any problems? I would like to beef up my stereo a bit for the carpc but am afraid of damaging the HD...
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
    from what I remember from previous threads....it's not been a problem...
    I was running 143.~ dBs and didn't have a problem with my HD, thats not anything crazy in the world of SPL, but it's quite a bit louder than most street beaters out there in all reality.
    Jan Bennett
      My original carpc we stored in the trunk. It was strapped down right next to my speaker enclosure containing a 12" MTX. I ran the system for around 2 years (this was back in 1999) I never had any problems with the disk.
        I have a 12 w7 pounding just inches away from my harddrive for over 6 months with 0 problems.
          The probability that the HD get damage by potholes, crappy roads/suspension(car) is 10 more than vibration from the subs.
          BTW, this type of question/concern come up very often.
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            I kept corrupting my HD by having the sub box too close... I believe that the electromagnetic field is probably the harshest part of the car environment... I didn't figure it out for a long time and it was really beginning to frustrate me... now the only time I have to reformat and reinstall is because I upgraded the HD... I know that people have mixed results, I would be curious to know HD brand/model, sub type/power and listening habits...
            EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
              True, however my original carPC used a Quantum Fireball. I was in a car accident and rolled my car and hit two utility poles. My harddrive was fine.. Luck of the draw I suppose
              Yes, this is why my case was shielded
                I used to do VJ work in clubs and lost 3.5" drives with remarkable frequency. Never lost a single laptop drive, though. FWIW...
                -g.
                  holy *****, you rolled the car
                  hope u walked away ok,
                  what did you use to shield the carputer???
                    i lost a 3.5 drive in my old college dorm room because of powered 12in subs
