tv out
  • tv out
    I have the epia 13000 motherboard. i cant get the tv out to work. what are the jumper settings and bios settings for this to work? i heard jumper 1 and two. i cant tell which pins those are. so are they the two closest to the port or the other two?
    not sure about jumper settings, I just turned mine on in the bios. The settings are pretty self explanitory, I'd tell you what they are but I'm not at that pc right now
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
      could use a little more help
        I can't remember exactly right now...however the trick is in BIOS.
        Here's a link to back when I had this similar problem...
        http://www.mp3car.com/vbulletin/showthread.php?t=46602
        Renault Megane...the OEM look
          I thought the Svideo worked regardless of the pin setting?? the jumper is ONLY for the RCA type jack - and allows it to be either digital audio or low quality video... from the looks of the diagram you would want the jumper on the "1", so it would be closer to the VGA port... and away from the PCI slot...
          also you can have either VGA or TVout... not both...
          EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
            You can have image on both. It's video playback you can't have on both at the same time...
              I have never tested my SP13000, but on my EPIA 800 you absolutely could not have both connected at the same time... it is not a dual head video card...
              and when you say "it's video playback", what difference does that make?? the video card still has the same responsibility... and he isn't looking for video playback exclusively - otherwise he wouldn't have a 13000...
              and I do know this for fact, there is no use for the MP4 decoder chip because the only drivers are in Linux... :-( I asked around at the VIA forums and nobody had a clue...
                ok i am still messing around with this. if anybody that is using the rca v-out could tell me thier advanced chipset features settings in the bios it might help. i would really like to get this to work. it is alot neater to run rca cable then vga.
                  i got it!!!!!!! i will post the settings so the 3 days of messing around might help somebody.
                  advanced chip set features in the bios:
                  select display device [CRT+tv}
                  tv type [ntsc]
                  tv connector {cvbs]
                  the jumper is on the side closest to the vga port
                    Realy im having huge problems with this
                    my TURBO! Altezza!
                    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
