Display Info - 2000 VW Passat
  • Display Info - 2000 VW Passat
    (Very Sorry if this has been covered)
    I have a 2000 VW Passat. I'm currently planning out may carputer, and would like to know some info on screens. Is there a VGA touchscreen display that will fit in my double din dash opening with out modification to the car?
    Thanks.
    the wrx convertion to double din should fit
    http://www.customcarcomputers.co.uk
      jrdwiz or turner brown,
      are you referring to the wrx double din bolt in kit? or were you referring to the tutorial out there to convert the passat's dash to a double din?
      have you tried that wrx bolt in double din kit that mp3car sells?
