2004 Ford Ranger Edge
  • 2004 Ford Ranger Edge
    Howdy Folks,
    I Recently decided that I am going to install a PC in my truck after about a year of kicking the idea around. Does anyone out there have a ranger with a system installed in it? I would greatly appreciate some insite on getting the job done. The only problem I have is that I am in Iraq right now and waiting to get home but I have all the things I need to put the system together and I guess the only real problem i am having is figureing out how to tie the computer into the stereo system ( Insite there would be greatly apprciated as well. Tahnks for your time in advance and I hope you guys have a great day.
    I have an 03 edge and i installed a carpc about 4 months ago. For the motherboard i used the m1000 and mounted it behind the screen in the dash. I mounted the screen where the radio was. i just cut out the bottom so the screen would fit in the hole and it looks okay, good enough until i get around to flush mounting it .The power supply (i used an m1atx) is to the right of it. and the harddrive is attached to the metal bracket that is behind the radio bezel on the right. For the stereo i have a 4 channel amp beind the seat that is connected to the motherboard with a headphone jack to rca converter. I install have some pictures of my install if your interested let me know.
      Please do i would love to see what it might wind up looking like. I've got the equipment figured out that I am going to be using it's just a matter of getting it together so i can build it and have it ready for when I head home. Thanks for posting the pics in advance and take care.
        The stereo part depends a lot on whether you are going to keep the existing headunit or go without a headunit. I have chosen to keep my headunit for those times when the PC is "down"
        2005 Black Chevy Impala
          And that makes sense I'm just not sure if my head unit has the Aux in port on the back of it. It's the factory Headunit with the edge.
            Another question I have is this: Since the XM-PCR has been killed how does one go about getting XM into the system? I found a great front end I really like that supports Xm and I just need to figure out how to integrate now.
              i believe i read something about splicing into an "xm direct" module. search for "xm direct" and it should bring up stuff about it.
                I have an 03 Ranger FX4. Check the link in my sig for my project details. I'll answer any questions you have.
                Current Vehicle: 2007 Dodge Nitro
                Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
                First Vehicle: 2003 Ford Ranger
                  Ok I think I finally narrowed it down to what I am going to use to build the PC. The list is as follows:
                  Hardware:
                  VIA M10000 W/ PCMCIA and CF slots ( Seems to be a popular choice )
                  512 MB Ram
                  Sony 24x CD-R/RW / DVD Combo
                  MINI ITX case ( Notebook size to shove under the seat )
                  100 GB HD
                  8" Liliput TS monitor
                  USB HUB ( For all the other little goodies )
                  Software:
                  Windows XP SP2
                  Norton AV ( For the wireless portion )
                  Nero 7
                  Net Stumbler ( War Driving )
                  Mobile Impact Front End
                  Optional Stuff:
                  GPS Navigation system using IGuidance
                  XM Radio using the Hybrid Cable and the XM Module
                  USB Wireless adapter
                  What's the opinion on this setup? Any suggestions?
                    I will be selling my motherboard, case, PW70-A PSU, Carnetix P1260, and XMD1000 next week if you are interested..
                    You will have a very tough time fitting anything under your seat..
                      My screen is the same as tbird2340's but like i said the motherboard and power supply are in the dash. Sorry i have not been able to get pics yet. I will try this weekend to get them up.
                        Heres my '04 Ford Ranger Edge. I went a much diffrent route then most people.
                        As for fitting something the size of a laptop under the seat..you're probably going to have some trouble with that as previously mentioned. I have an ATX power supply under the seat, and width wise, it's a pretty close fit.
                        And the stock Edge H/U (at least for an '04) does not have aux-in. Personally, I bought a H/U with aux-in..I wanted one for fm radio and thoes 5 minute drives where you really don't need the computer.
                        Take 2 - '03 Audi A4
                        macmini with an 8" widescreen (in progress)
                        My 2004 Ford Ranger:
                        14" LCD w/ custom made aluminum bezel
                        Completly custom computer case
                        status: Totaled
                          Nice work so far Rocky. I'd like to see it when the project is done. The only problem I have with my install and deciding on a location for everything is that I am in Iraq and my truck is in Texas hehehe. I will get home on leave and go nuts getting this thing installed. I will have everything for it here shortly here in country and then take it home with me when I go home on leave.
                            The power supply is about where the red square is but you cant see it because of the hard drive. I used the power, ground and remote lead from the headunit wiring harness since i didnt need the headunit anymore.
                              Brandonn: What size monitor is that? I like the completed look by the way. Very nice.
