Carputer for 2005 Nissan Altima
  • Carputer for 2005 Nissan Altima
    Hello everyone.
    I am new to this carputer stuff, but I am very excited about starting this project.
    I just bought a new 2005 Nissan Altima. After doing lots of research on the forum, I decided to go with this setup. I wanted to get your opinion and maybe some recommendation on these parts that I want to buy before I make any mistakes. For the computer I decided to go with the mini ITX and for the monitor I want to get the Lilliput 7" VGA Touchscreen. Here is a brief list of the hardware I am planning on buying:
    - C134 Mini-ITX Case Black $140.00 (I wanted to go with the Morex Cubid 3688 Mini ITX case but it is not standard DIN, and since I wanted to mount the computer on the dashboard for easy access to usb ports and drive bay, I decided to get the C134)
    - Lilliput 7" VGA Touchscreen 619GL-70NP $254
    - VIA EPIA SP13000 Mini-ITX Motherboard $225
    -Pioneer Slot Load DVR-K05 DVD±R/+R DL/±RW Dual Drive 8X $145.00
    -2.5" Hard Drive 80GB Samsung 5400rpm $240
    - Ultra Low Profile 512MB DDR PC3200 RAM $148.99
    - Audigy 2 NX external USB sound
    - Power Supply ( Don't know yet - Which should I get for this set up? )
    - AMPLIFIER ( Don't know yet. Any recommendation would be appreciated)
    - Speakers + Sub ( Haven't decided yet, also here any input would be appreciated)
    - GPS ( Don't know which one to get yet)
    - WIFI
    - Keyboard and mouse (wireless preferable)
    I think that's it, hope I did not forget anything too important.
    This is what the dashboard for the 2005 Nissan Altima looks like:
    I am thinking of mounting the monitor right where the small compartment is
    and the computer wight below it where the LCD discplay is. I will probably have to take it to a shop to have it mounted since I am not very handy when it comes to these type of work and I do not have the tools. I have built many PCs myself ( desktop ), so I should not have problems with the PC set up and the wiring.
    I have a budget of 1500.00 for the whole project, I don't want to spend more than that. I plan to finish it in probably 2 months if everything goes as planned.
    If anybody is familiar with a good shop where I can have the monitor mounted, that would be great, I live in MD.
    Thank You.
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    take a look through the projects threads there are a number of 02-04 nd 05-06 altimas with screens mounted where you are considering (above the radio) One of the mods of the forums (altimat) had done a while back and sold them for the 02-04's
    good luck on your project. Personally i would use differnt hardware, but i also was not looking to install my computer in the dash. You should be able to complete the project for around your budget.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      So I changed my mind, and did a lil more research,
      I am not going to install the computer on the dashboard,
      but below the passenger seat.
      This is my first diagram as to how I am going to do it.
      Please feel free to give me any feedback or recommendation.
      Some of the hardware parts I want to get, I have identified;
      the others, i am not decided yet.
      Here is what the wiring and placement would look like, looks like I will need long cables and wires.
      The hardest part for me would be to mount the LCD on the dashboard,
      since I do not know how and do not have the tool, I have decided to
      buy the dashboard frame from the 05 altima that has a navigation system,
      I can then use the cutout of the LCD to place my own xenarc LCD. Hopefully
      it will fit.
      my car
        Look at Altimat's installs.
        Renault Megane...the OEM look
          Here I go again. Well I changed my mind on a couple of things.
          1- The monitor will not be located on top where the small compartment is, I will mount it where the radio is see http://www.mp3car.com/vbulletin/showthread.php?t=44943
          2- I have decided to go with a destop PC, a MicroATX case and motherboard
          For the case http://www.tweaknews.net/reviews/a106/index2.php
          http://www.newegg.com/Product/Produc...190-018&depa=0
          http://www.xpcgear.com/lib/extremepc...se-03-256k.wmv
          I wish the LCD display was horizontal so I can place in the dashboard.
          with a 2.8 Ghz Intel Pentium 4 processor. I have not decided about the motherboard yet, but most likely will be an ASUS microATX.
          -A desktop 3.5'' Hard drive instead of a 2.5''HDD
          -150W opus power supply
          -The monitor will be power by the OPUS.
            After 1 month of planning, I came up with this. I am about to purchase the parts next week.
            My concerns so far?
            Will I have enough power on the M2-ATX to power my peripherals?
            Do I need a second battery because of the inverter I am using ( although I will not go pass 200W on the speakers)
            I will first test everything on my bench and measure all voltage rail power to make sure everything is working fine.
            Then I will take everything to the car and install the inverter and the PC, then measure the power on the inverter when I am listening to music and see how high is enough.
            That's about it.
            Please comment...
              why go with a 64 sempron when NOTHING you'll run inside the car is 64 bit? i have a 2800+ mobile athlon with just about every peripheral one could think of installed on a m2-atx, but i'm not sure the 64 sempron will allow it.
              Live mp3Car Facebook Chat
                Thank You, will consider that...
