Opus150 & Laptop?
  • Opus150 & Laptop?
    I have an opus150 that was going to be used for a mini-itx, but that fell thru and I am now running a laptop based carpc setup using an inverter.
    My question, is it possible to use the opus to power and startup the laptop? What converters/adapters/materials would i need?
    I'm aware that a lot of people are using laptop setups in their installs, and I can assume they all aren't using crummy power invertors like me. I ran a search for opus on a laptop, but came up short. Hoping someone has some info on this. Thanks.
    edit// I was browsing around and I found that turbocad6 is using a opus-laptop install. Help me out man
    bump?
      two quesions:
      laptop input voltage = opus output voltage ?
      max watts drawn by laptop < opus available watts ?
      "help me help you"
