How do car computers work when you start them and some other questions?
  • How do car computers work when you start them and some other questions?
    Like, when you start your car, will you have to wait a couple minutes for the computer to load up or is it pretty quick?
    and those shutdown controllers, do they allow you to just turn off the car and stuff? and the computer will shut down safely?
    the computers connect to the battery correct? do they still use the computer power supplies? or does it use modified ones?
    check out the faqs there or different ways of doing this, quick and not so quick. do a search about 'boot time' and xplite and you'll find more.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      heh... i see you're a regular at bit-tech. :-)
      M10k
      My Car Pc Install
      My Boat Pc worklog
        How fast does your computer turn on when you push the on button?
        Shutdown controller does just what its name says.. Works like an amplifier, turn key off, remote signal is lost, computer goes into shutdown mode.
        Link to a DC-DC power supply:
        http://www.mp3car.com/store/product_...roducts_id=171
        Look in the mp3car.com store for more w/ info.(click on the logo at the top left).
        Jim
        2012 Honda Pilot (In Progress)
        2010 Honda Accord (After the Pilot)
        2008 Honda VTX1800N
          here are some links:
          Start here is has everything you could want:
          http://www.mp3car.com/vbulletin/foru...e=2&order=desc
          This one talks about which power supply to get:
          http://www.mp3car.com/vbulletin/showthread.php?t=68636
          This one is more info one power supplys:
          http://www.mp3car.com/vbulletin/showthread.php?t=51060
          This one is about DIY startup/shutdown controller
          http://www.mp3car.com/vbulletin/showthread.php?t=54143
          You know you're an engineer if you have no life & can prove it mathematically.
            did you just check out bit-tech or something?
            so with that one psu you linked, does the mobo plug into that? where does it connect to the battery? you put the controller before it right?
            in the power supply link it says eventually a pc WILL drain your battery in a few days, so how do you prevent this?
              I didn't read the link supplied but the battery shouldn't die since the computer is only running for a minute or so after the car is shut off...
              A basic shutdown controller does the following...
              You shut the car off
              the controller loses power on the acc lead
              controller starts an internal timer for killing the constant 12v lead
              controller shorts out what is hard wired to the power button on the computer
              pc starts the shutdown process
              controller timer eventually reaches 0 which cuts the 12v lead in case the computer didn't shut down successfully
              controller waits again for the acc lead to be powered
              Some may be different but thats the general idea...
              1997 Saturn SL2 Car PC Status [..........] 0% Complete (Removed)
              1999 Honda Accord Car PC Status [::::::::..] 80% Complete (Setting up software before final install)
                well in the link it says
                Vehicle batteries can provide a limited amount of electricity to your devices. Even if your computer is completely OFF, a PC will still consume a few hundered milliwatts, needed to monitor PC ON/OFF status. When the computer (car pc) is in the suspend/sleep mode, it will consume even more power, because the RAM needs to be powered at all times. The power consumption in the suspend mode is few watts. No matter how big your car battery is, a PC will eventually drain your vehicle's battery in a matter of days.
                but i think maybe its just for suspend mode?
                so boot time takes around 30sec to a min or so right?
                  yeah i'm not sure how many people use sleep or suspend mode but I personally use hibernate. coming out of hibernate my computer is usually booted by the time i'm out of the driveway and start going down the road (18-23 seconds?)
                    i always check out bit-tech for ideas and just to see how crazy those guys are with there amazing installs. puts most of ust to shame really. I saw the thread about car pc's and i recognized your name
                    as far as it draining your battery that is only in suspend mode. hibernate or complete shutdown wont drain your battery (at least using the m1-atx, the opus .. unless modified, will eventually drain your battery from what i remember)
                    I do a complete shut down and now it's taking a lot longer to boot (well maybe not boot but from the time i start the car to the time centrafuse starts to play musice) since i installd the obd-ii and bluetooh. the more streamlined your set up os the faster you'll be able to boot.
                    also the search keywords i provided you will shed a lot of light on how to get faster boot times.
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      if u use a good start up/shutdown controller, it will consume no voltage when the system is shutdown, the su/sd controller will turn all power off to the mobo after the mobo turns off the power supply. the power supply returns power just before appling the startup signal to the mobo
                      95 Mazda Protege LX
                      Worklog
                      Overall [Project Dead] 0%
                      2003 Nissan Altima
                      [XXXXXXXX--] 80% Planning
                      [XX--------] 20% FABRICATION/INSTALLATION
                      Worklog
                        You can also use standby, i use that and the system is playing music in 4-6 seconds.
                        1990 Jeep Cherokee
                        2000 VW Golf TDI 4dr
                        2005 VW GTI MKIV - SOLD
                          I hibernate to disk and when I start mine up, I'm playing music in under 20 sec.
                          How about the Wiki?
