Powered USB hubs
  • Powered USB hubs
    I have and and but im going trying to find the answer.
    Please someone one help me with this. I have a powered usb hub. I understand that i need 5 volts to power it. Im pretty sure i can get it off my m2-atx power supply. My question is how in the hell do i do that. Do i just get a plug and cut the wires and hook it up to the power supply? if so where do i hook it up on the power supply?
    My car
    http://www.mp3car.com/vbulletin/showthread.php?t=78111
    Im now selling my jeep computer.
    Tap into a 4-pin molex connector (otherwise known as a HDD power connector).
    Red = +5v
    Yellow = +12v
    Black = Ground
    How about the Wiki?
      cool thanks.
      so i just take like the wall adaptor and cut the plug off and plug it into a molex connector?
      My car
        damn double post
        here is my hub
        My car
          Originally posted by 2000Jeep
          cool thanks.
          couldn't tell if you'd done it already, but yeah, if you're not going to use the hub in the house anymore, yeah, just cut the plug and wire it in. Just make sure your polarity is right.
            Cool, thanks guys
            My car
              red wires on the molex, not the yellow ones...
              1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
              Pictures
              Photobucket is being updated, if a picture i posted no longer works, please PM me.
                ok, yellow is a no no, red is a go
                My car
                  LOL sweet... but yep.. you got it, at least in this application
                    thanks guys. I got to get power to the hubs and tot he PC then work on my detachable faceplate again (check link at bottom) and get it installed then hook up my new amp and sub then i should be done.
                    http://mp3car.com/vbulletin/showthread.php?t=76669
                    My car
                      How is the best way of doing this?
                      My car
                        well your ac power adapter should say which part of your plug is positive and which is negative, so taking that, and a multimeter, check the wires (once you cut the plug off from the adapter, and see which wire matches up with the positive/negative respectively. use the continuity/beep/short setting on the multimeter.
                          intersting... but what if you need something like 8 volts, where do you draw this from... or would you use the 12v line with a resistor?
                            What would you possibly need 8V for ?
                              I have two usb hubs, one uses an 8v input, the other 3v... hence my question!
