my freedom mini keyboard isn't connect ?
  • my freedom mini keyboard isn't connect ?
    Hi guys,
    Even though, I can see my keyboard on the bluetooth, but I can't connect it, here is the picture? any idea ? please help. Thanks
    Enter the correct passkey.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      the problem is, I can't type anything with my Freedom Mini Keyboard
        you have a mouse right?
        Click Start -> all programs -> accessories -> accessibility -> ON-SCREEN KEYBOARD
        or just connect a regular keyboard to enter it.
        Installed
          sorry, I meant that, I have my home keyboard, and I just want to test the freedom mini keyboard before I put it in my car, and I tried to connect it with my blue tooth, and it asked me for the passkey, but I can't use my freedom mini keyboard to type those passkey ? thanks
            ofcourse you can't you the wireless keyboard to enter the passkey, because the two devices haven't been paired yet. Use te on sceen keyboard to enter the passkey and then you can use the keyboard.
            Installed
              I just used the one on the screen and typed in the passkey then click enter, it's still doesn't work.
                never mine, thank you very much guys, it is working now. this keyboard is awesome.
                  so what was the problem?
                  Installed
                    The problem is, when they asked for the passkey, just enter the 6 number on the freedom mini keyboard, but I don't know how to type in the number.
                    Actually, I need to hold down "Num" then I can type the number in, after that it will work. But whenever I don't use it for like 5 mins or less, then the keyboard will automatic turn off or something, then i need to repair it again; how to fix this problem ? thanks I am using the mini keyboard to type these
                      There should be some sort of pairing sequence for the keyboard to remember the key. Look in the manual for the keyboard.
                      And you have to type in the passkey with the keyboard, of course the on-screen keyboard wouldn't work because the bluetooth software was looking for the PIN from the bluetooth keyboard as an authorization.
