Question about Renault megane cd changer
  • Question about Renault megane cd changer
    hi every body
    first i am sorry about my bad english
    i ask about if i can conect my cd changer to my carpc and what part use
    and control soud from my carpc or my cd changer device
    Why do you want to connect your CD changer to the PC ? I speak french also if you do?
      hi kevinlekiller
      i want to connect my cd changer device because i don't want to put my carpc screen in its place but i am searching for another place for my screen
      so iwant to connect my cd changer to carpc because i want to keep it in its place
      for this iwant to know how to do this work and what parts i need
      kevinlekiller
      i want to ask you another Question
      can i wire the speakers (the orginal in car) into my car computer and play music on thier
      thanks alot
        By CD changer, you mean a CD player ; Example: Click me
        And not a CD changer , example : Click me
        To connect , you need to see if the head unit as a input , this can be a CD changer Input or a RCA female connector input.
        If its a CD changer connector input you need something like this :
        http://www.crutchfield.com/S-irsY6MP...p.asp?g=234650
        You have a Renault , so Im not sure what brand of head unit Renault uses (stock) , it might be some brand that you cant find a cable , in that case you need to buy a new head unit with aux input ( rca female connectors ).
        If you have Rca female connectors on the head unit , then you just connect that to the pc , with 2x male RCA to 3.5mm stereo connector.
          Also , you can use an amp , then the PC connect to the amp , the PC acts as a preamp(instead of the head unit). This way , its easier to place the screen.
            question megane cd changer
            hi
            i bought original cd changer megane but i haven't cable for connect to radio
            cd changer have 15 pin and pin layout
            1-8-9-11-12-13 GND
            14 NC
            15 Batt
            6 Acc
            2 Rxd
            3 Txd
            4 Radio
            5 Power
            7 IR-out
            10 D-out
            please help me how can connect changer to radio ?
            thank you
              Hi. Does any know where I can get the same lead as what is needed in the previous post? Or know what make it is? Cheers
