Important CarPC Power question
  • Important CarPC Power question
    I have purchased myself a new CarPC its power pack transforms 110v to 12v 4500mA
    and...
    240v to 19v 2950mA
    now if i hookup this carpc strait to my car battery (without putting it through it power pack/transformer) which puts out appx 12.9v at 15-20 A will it be fine or will the amps be to much for it
    im a tad new at this but it sounds like it should work
    but i would fuse that bad boy. with a 5 amp fuse or something.
      might i say your username is quite accurate...
      please read the FAQS and no dont do it the 12v is unregulated and will Blow the sensitive computer components
      search b4 u do then search again or else your username might be part of your future for sure
      .______
      | '_ |__\___
      [(o)|___(o)] XB
      ._________
      | I__I I_I|_\__I
      [(o)______(o)]b VanPimpin'
      LostReceptions Apps D/L Here
      GPSGasoline- Rewriting
      CarPCNetwork
        so thats the point of the dc-dc converter...is to regulate it?
          yes otherwise you have voltage spikes when u start your car etc
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          CarPCNetwork
            i searched the faqs and there was nothing specifc to what i want to do they all talk about wanting to have use pcs that have 110v or 240v psu's where mine has 12-19v psu
              what he ment was that you dont have to use the transformer you have. (well really you cant without a inverter.) but if you are going to power it from your 12v car bat. that you should use a DC-DC converter. and there is plenty of info of them in the FAQ. and at the mp3car store.
                I must say that I'm dumbfounded.
                Why would you tell someone "sure, why not!" when you have absolutely no idea what you are talking about?
                Jan Bennett
                  http://www.mp3car.com/vbulletin/showthread.php?t=51060
                  Even more important
                  Battery --> Regulator --> startup/shutdown controller --> Power supply --> Computer
                  That thread should help...
                  Most power supplies listed in the sites store and what not have built in Regulators and startup/shutdown controllers and are power supplies...
