new dvd burner..windows won't recognize
  • new dvd burner..windows won't recognize
    having trouble getting my dvd writer installed. it's a pioneer k05 slim slot load laptop dvd burner. i manually installed it into my laptop (to test, i don't have the rest of my carputer yet.) windows (xp) won't recognise that there is a disk drive in there at all. the dvd drive didn't come with any drivers or anything, and it is new. it's getting power and accepts and ejects disks fine. i tried uninstalling the old drive from the device manager so windows could recognize new hardware, which it did. however, when it recognized the new hardware, it recognized it as my old disk drive, not the one that was actually in there. if put the old one in, it works fine. any help is greatly appreciated...and yes i've tried searching both this forum and google for a few hours already. sorry if this is a total noob problem but i just want to get this working so i know it works. thanks
    VIA Epia M10k, M2 ATX PSU, Pioneer DVD slot load slim Writer, Lilliput 619, WD 3.5" 80Gb HDD, BU-353 w/iGuidance v.3
    Dash Fabrication 100%
    Computer Setup 100%
    Did you happen to reboot between switching roms?
    Tidder
    Try RevFE
      yes, each step was followed with a reboot
      Computer Setup 100%
        That sucks. Maybe delete the entries out of your registry as well? Out of the controlset 1 and 2 and also the currentcontrolset. If you don't know what I'm talking about, then it's probably not a fix for you to perform.
        After you delete the keys that have to do with the cd-rom, reboot.
        Does it detect it at all? Or just detected it as the old rom?
        Tidder
        Try RevFE
          when i delete the current one out of the device manager, and boot with the new drive in, it detects new hardware, but says it's the old drive. it just installs the old stuff back where it was like it's the old drive hooked up.
          Computer Setup 100%
            Wow, that is a little strange. Do you have a cd you can try to boot off of to see if your drive works outside of windows?
            Tidder
            Try RevFE
              no, but i should be able to make one using my other cd writer right? not really sure how i do that though, other than changing the boot priority in the bios
              Computer Setup 100%
                Does your lappy have a floppy drive? One that you can use while keeping the rom in as well? If so, just boot to floppy then see if you can dir a cd from the rom.
                Tidder
                Try RevFE
                  no i don't have a floppy...can i use a usb thumb drive?
                  Computer Setup 100%
                    Eh, I don't want to even go there man.
                    How about a cd that came with the laptop, one of those should be bootable...
                    Tidder
                    Try RevFE
                      lost the one that came with the laptop...i have a legit copy of windows though
                      Computer Setup 100%
                        try booting that windows disc then. If that works, then I guess your having some major windows problems.
                        Tidder
                        Try RevFE
                          nope doesn't work...i did set the boot priority to cd-rom in bios....i guess the drive just came bad. thanks for all the help tidder
                          Computer Setup 100%
                            Dang, that sucks. Hope you can return/exchange it.
                            Tidder
                            Try RevFE
                              yea i can i have to pay shipping though
                              Computer Setup 100%
