VIA's boards and upcoming boards
  • VIA's boards and upcoming boards
    I am doin some research on what board i want for my carpc and was wantin some little help with the experienced users here.
    I was lookin at the EPIA-EN boards, EPIA-CN boards and the new Nano EPIA-NL boards.
    Now, from what i gathered-
    CN uses the new C7 chip offering a max of 1.3ghz and faster memory.
    EN uses the C7 chip with a max of 1.5ghz
    NL nano uses Corefusion with a max of 1.0ghz
    The NL is over $300 easy, CN mid $200, EN just under $200.
    If taking for granted all 3 boards would be running 1gb of it's fastest compatible memory stick, would i still be ok just running the EPIA-CN board for mainly music\video and emulators?
    I just recently read somewhere else that Gigabyte was about to come out with their own Mini-ITX board but specs are kinda unknown...I'm waitin for a response back from them to see what the specs are and all that.
    And correct me if I am wrong but out of the CN and EN board, isn't the CN board the fanless design ONLY out of the 2?
    I will recommend the EN boards. The performace of the C7 1.5 in my opinon performs better than a pentium M 1.73.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
      so I'm guessing you got windows installed on your EN inniss?
      Jan Bennett
        which one of these boards are fanless?
        Also, Gigabyte will be releasing their Mini-ITX at the end of September. IT is suppose to be a C7 2.0GHz
