Compatibility: 4 Pin ATX power socket + M2ATX?
  • Compatibility: 4 Pin ATX power socket + M2ATX?
    Dear all,
    Have been a long time lurker and a first time poster.
    Before hand, would like to say a big thank you for the wealth of information provided by this forum.
    I've gotten all the parts to start my installation until I notice that the M2ATX is not recommended for
    Please check your motherboards specifications and make sure that the CPU is not getting V(core) from the 12V rail (should be on the 5V rail).
    Not recommended for motherboards with Pentium 4s and motherboards that have 4 pin 12V ATX connectors, which is an indication that the motherboard is using 12V for V(core).
    Got the info HERE
    My mobo is MSI PM8M3-V VIA UniChrome P4M800CE Socket 775 mATX MB w/Vid. Link HERE
    I'm not sure if the mobo has V Core, but it does have a 4 Pin ATX power socket for the CPU there... The manual says it's for optional P4 power supply?
    I'm using a Celeron 2.66Ghz CPU.
    Am I screwed?
    HELP?!
    Oh, and thanks in advance, guys and girls!
    I don't think the Celeron requires that connection to be made.
      Hi, thanks for the fast reply.
      So, for non P4 proc I'll just leave it unplugged, rite? Well, seems like I'm safe for now.
      Thanks again!
        If the motherboard uses that 4-pin 12v connector, it probably won't boot up if the 4-pin connector isn't connected and providing power. I don't think the CPU requiring the 12v conenction has anything to do with it.
        How about the Wiki?
          My Soyo K7MVE socket A mobo for Athlon CPU require 4 pin 12V to boot. Without it, only the CPU fan spin and nothing else.
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            Yup, same with my Jetway board in my ride.
            Tidder
            Try RevFE
              Thanks guys!
              I went scouting for the 4 pin power socket. Guess what? None available locally!
              I ended up buying a whole PSU just to get the socket!!!
              Well, at least I now have a PSU to power up my carputer at home...
              Well, maybe it's easily available in the USA/Europe, but where I stay. None. Maybe the moderators would like to put this up as a reminder to newbies when they start to purchase parts?
              Thanks!
