ok i know how to put a pc together but not like bios stuff
  • ok i know how to put a pc together but not like bios stuff
    i know how to put everything together but how do i like install/setup the bios and windows and all that stuff.
    building a pc for friend then car pc for me. my pc i have now was built then i put a whole bunchh of new parts so i dont know how to do bios and os and stuff
    You can build the PC, but you can't do the BIOS or OS?! That's half the install right there.
    "It's a blessing . . . and a curse."
      The BIOS is already installed. You read the manual to see what each option does.
      To install Windows, set the BIOS to boot off of the CD/DVD drive insert Windows disk and follow prompts. Assuming your using XP, of course....
      You should probably try a few more desktop installs before you try to build a carputer. They can be somewhat tricky. Check out some general pc forums for awhile...
      Not trying to be snobbish, but you really should have some basic computer understanding before you start hacking your car's interior apart.
      -ZtH01
      "It's my belief that my big balls should be held every night"
        ive done like cathodes new fans strobe lights dvd burner and rerun all the wiring in my pc i think i can put it together good but could a computer store do the bios and os for me do u think
          ODYSSEY
          Originally posted by Tidder
          Digital-Car UK|
          (\__/)
          (")_(")
            Originally posted by ODYSSEY View Post
            i take it this is bad
              Try here for help - http://www.angelfire.com/rings/judy_patch/
              ODYSSEY
              Digital-Car UK|
              (\__/)
              (")_(")
                NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                Never visit.... Kills brain... cellzzzzzzzz.
                An untraied monkey (like xbrady's avatar) can put together a computer. It is getting the thing to POST, getting the fiddly M$ OS on there without the blue screen of death, loading all the drivers that the manufactures handily forgot to put on CD's, finding out that someone has hax0red your XP liscense and finding a way around it, without talking to your soon-to-be-best-buddy in the Indian offices of Microsoft Product Activation only to find out, that after all that work, flames are shooting out the back because you weren't watching the computer, and you didn't secure the heatsink properly and used no thermal paste, so your CPU's transistors explodimified sending silicon shrapnel into your skull, and WHY?????????
                Because putting the parts together is easy. Getting the PC working well is not as easy. Eventually you will get the hang of it, and make yourself a slipstream XP install CD, so all you do is pop it in at night, and when you wake up, your PC is booted into XP, already activated, all your favourite software already installed, and your preferences are already setup... Ahhh, the good life!
                1.9in x 2.9in -- 47mm x 73mm
                  i think ill just pay a store or my friends bro to do os and bios once i do car install
                    Very rarely do you ever need to update the BIOS. Also how will you ever learn if you pay someone else?
                    It is simple, once you know what you are doing.
                        I think this person needs to better understand computers before he goes much further.
                        Sounds like someone has just heard the word 'BIOS' and just thought, I need that....no thought or research into what it is, how it works, why you have it and need it, nothing.
                        Sounds like the OP needs to do a bit more research, or throw money at the problem like he's suggesting, and it will go away.
                        Jan Bennett
                          Without knowing how to install an OS, I would advise you to stay away from this hobby. You will WASTE your time, effort, MONEY, energy due to cursing.
                          Also, if you aren't familiar with how car electrical system work or audio system, you are asking for disaster. If sound crazy, but you can accidentally set you car in flame. Worst case, you can kill yourself and somebody else as well.
                          Y2K Accord Dell GX150
                          EmoRebellion is a SCAMMER
                            Very informative! I had no idea hard drives had IP addresses!
                            -ZtH01
                              You'll never learn if you let the store do it. Have your friends brother help you. You'll learn a thing or two that way.
                              -ZtH01
