Need advice where to shop? Please
  • Need advice where to shop? Please
    OK I am using my laptop but I dont wan to to break apart and rig it to power on with a car and I am tired of takign out at the end of the day.
    So I have 600 Dollars I can spend on a car pc
    this is what I want from it and if you could find one I will be very thankful.
    at least 1.5Ghz but I seen 2Ghz
    184 pin Ram
    preferably p4
    ma2 automotive power supply build into the case or buy separatly but need to go inside the case
    can support sata
    usb
    and the case can not be gigher than 2inches and long and width be below 10 inches.
    I have seen 8x10
    all under 600
    main thing I want it powerfull enough and small enough to fit underneath an eclipse 1995.
    ccortes@smscorp.com
    dont wanna flame you, but, look in the mp3car store, look at newegg.com
    look at any computer store
    the mobo and processor will set you back around $100-$150, (u didnt say how much ram), ma2? u mean, m2-atx? o_O
    usb is off the mobo, u'd be hard pressed to get a p4 mobo without USB
    case?, look around
    and under an eclipse? better waterproof it (i think u mean under the seat?)
      Generally in computing these three qualities cant be achieved simultaneously:
      -Cheap
      -Efficient
      -Small
      Usually one must be sacrified to achieve other two... i think u might wanna keep that in mind to avoid dissapointments...
      Also are u planning to run it headless??
        http://store.mp3car.com
        http://www.logicsupply.com
        http://www.newegg.com
        http://www.mini-box.com
        Just for starters.
        I would strongly advise against asking people to do your leg work for you on this board. There are many reasons I would suggest doing your own research.
        You need to know what you are running and why. Theses things are critical if you plan on implemeting a pc in your car.
        Jan Bennett
          main thing it be used for navigation and music storage and recording xm to hard drive. Also yeah under the seat sorry. I ask here because maybe some one ahs done what I wanted and they point out and say hey theres a web site that sells them in a bundle. I will check those web sites out. Like I said I want at least 1.5Ghz and less than 2.in high no more.
          ccortes@smscorp.com
            did you read what we all posted for you?
            you can get bundles, look in the mp3car store, and pretty much everyone has done what your asking, look in the show your ride section for pictures
              Yeah and i wanna be forever young... however realities of life are against us... I dont think u can achieve all of that with 600 bucks... sorry...
                take a note for example this guy... he bought everything cheap from ebay... he barely made under your limit, if we count off second processor... and yet the guys (usable) processor is not even nearly enough efficient for your minium requirement.
                http://www.mp3car.com/vbulletin/showthread.php?t=82022
                My point is... u will have to flex a little, either size, money, or efficiency wise...
