  • question
    A little confused...
    In the description of the M2-ATX from the mp3car store it says this PSU can handle 8A on the 12v rail, meanings it can handle only 96w. Why then is it advertised as being a 160w output PSU? Is this because it is a sum of the wattage supplied by all three rails?
    One more thing kind of off topic, is there a difference between ITX motherboards and ATX motherboards? the descriptions in the store say some PSU's are for ITX mb's and other say ATX, is there a difference?
    First, you need to quit asking quyestions int eh FAQ Emporium subforum unless you're adding information.
    Second, you're correct. The 160w rating is the total output on all three rails. 96 + 24 + 40 = 160.
    The rating is calculated the same as the rating for a desktop power supply.
    How about the Wiki?
      size and mounting points are one major difference between the itx and the atx boards. they use the same power connector so you'll be fine with the m2-atx as long as you are within the power requirments.
      New System in progress:
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
