Nissan 07 VERSA (Replacing Stock Headunit)
  • Nissan 07 VERSA (Replacing Stock Headunit)
    I really need some help here.
    No, I've read enough to remove the vent panel / console cover...
    I need the wiring diagram since there's no aftermarket wiring harness available yet. I also read something about needing an antenna adapter.
    So what's the deal?
    Any help is apreciated.
    Here's some info I've found via GOOGLE:
    Brownish-Orange (the thickest lead) - 12v Constant
    Orange - Illumination
    Cyan - Switched Lead/Accesory wire/Ignition wire
    Black - Ground
    Grey - Right Rear Negative
    Teal - Right Rear Positive
    Purple - Left Rear Negative
    Red - Left Rear Positive
    Brown/Pink - Left Front Negative
    White - Left Front Positive
    Green - Right Front Positive
    Red/Blue - Right Front Negative
    I also have MUTE/ANT/GRD/SAFETY GRD/ILLUMINATION wires on my headunit, these are the ones I've having trouble figuring out. I figure I don't need the ANT wire hooked up (it's for power antennas) and I have the stubby XM style.
    check this site out
    Search this site http://forums.nicoclub.com/zeroforum/185 , i found something on there not too long ago about HU wires
    What Versa did you get?
      Yeah, this is where my info's from...
      http://forums.nicoclub.com/zerothrea...postid=2190426
      I just got the standard Red Alert Versa.
        Nissan kicks ***! Good pick.
        Brent
        1999 Nissan SE-L - turbo toy
        1993 Nissan NX - Turbo Racer
        Standalone fuel management (AEM EMS) on both
        carPC
          Circuit City and Best Buy both won't touch it, since there's no harness available yet.
            You still need help with this?
