Screen and motherboard Suggestions
  • Screen and motherboard Suggestions
    I have a 2006 Honda Civic SI, and i am putting a carputer in my car at the moment, i currently have a DDX7017 but i am selling this.
    I already have an Opteron 165 Socket 939 and i would like to use that so i dont have to go buy a processor.
    Any suggestions for Screen + Motherboard to use?
    i dont need a screen that rotates or flips or anything... its a double din, so the screen will always be out...
    suggestions?
    I'd suggest on the screen that you check out store.mp3car.com
    and based on your budget make your decision that way. If you have questions on each model, I'd recomend using the search function with the model number as the term as there are a ton of threads out there where people discuss issues, pros, and cons of each.
    Jan Bennett
      Well, im not sure if the Opteron 165 is going to be to much power? i was looking at some of the PSU's and they are around 150 watts?
      i just need some suggestions on the motherboard and psu cuz i have never built a micro computer or anything of this sort.
        While this thread wouldn't answer all of your questions, it should help get you started: http://www.mp3car.com/vbulletin/showthread.php?t=78795
        Jan Bennett
