This is where is starts. tC CarPC
  • This is where is starts. tC CarPC
    **Okay, I am a car audio idiot, and forum dumb also.**
    So with that said, I stumbled upon bembowe's CarPC in his midnight blue tC and I thought it was hot. So I started researching. I came up with a parts list, and I made a diagram.
    I would just like your advice, and your inputs, did I draw anything wrong? (I'm sure I did) Just tell me how to correct it and if my parts list sucks or the information is incorrect, please give me suggestions. I have not purchased any parts yet since I'm not back in the states. This is for: 2007 Scion tC.
    Thanks in advance!
    Help?
    Insert a fuse close to the battery and use distro blocks to distribute +12 and ground. You can tap into your cigarrete lighter wire or somewhere in your fuse box for the ignition lead.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      looks good, except for a fuse on the main positive feed, and a missing fused distro block (can never be too safe)
      also you forgot the USB/Serial cable from the Touchscreen to the main board
      For Bootscreens click Here
        how do i get power to the monitor?
          With wire...
          Seriously...
          Search the forums. This is something that has been covered many, many times.
          How about the Wiki?
            okay.. my bad
              New here too, Thanks for posting such a detailed plan, this will help us all. I am going with a laptop setup, which you may think about with the costs of components that you are getting plus the addition of an OS.
              Mike M
              2006 Accord VP Sedan
              My worklog
              http://www.mp3car.com/vbulletin/work...-dads-car.html
                I updated the diagram with suggestions.. anything else i missed?
                  Up there by the monitor, you don't need a relay, you can connect the "turn-on" wire directly to the M2. Also, you can power the monitor by taping into the M2's +12 and ground output.
                  EDIT: Good luck with that M2, it's a toss-up whether it will work first time around..
                  OLD SYSTEM (DEAD)
                  M2-ATX Power Supply
                  Windows XP SP3
                    thanks treetop i see what you're sayin.
