I want a solid platform! where do I start Powerwise?
  • I want a solid platform! where do I start Powerwise?
    Hey All I'm not new to the forum been watching a while but I believe I am ready b/c I just bought a truck and I want to set it up so that I can build it in the future but I want to get the power setup so I can use tons of accessories then integrate them later with a PC.
    It is a 1996 Dodge 2500 Cummins Diesel. IT has dual batteries already and has an high-output alternator b/c diesels need the power at lower RPM's. It does have two amps and a head unit installed but because of the birds nest of wires is why I want to redo the power supplying it as well as have enough for using my laptop, GPS, Extra lights, as well as a Auto cooler that I keep with me on road trips!
    I will add a screen or two as well as DVD player and a more permanent computer but I don't want to start building a PC and find I need to find more power to run it!
    Any help or direction is appreciated. I saw the FAQ on inverters and converters but that sounded like more way to power the PC and accesories itself. I'm asking now what should I use to get a good source of power from. Like Should I get a board or a block to just tie everything into b/c I want a clean install and not everything jumbled up on the batteries and nest of wires balled up under the dash! Thank you for your time!
    Justin T.
    distribution blocks.
    it to learn more. That's how it's done.
    run a single wire off of the battery back to a distribution block. From the distro block you branch off to each component.
    Jan Bennett
      If that what works best I'll look into it! Thanks
      JT
        JT
        it does work the best.
        1.9in x 2.9in -- 47mm x 73mm
