Changing the Jumper values on a M1ATX
  • Changing the Jumper values on a M1ATX
    Is it possible to change the timings on a M1ATX I do have a programmer knocking about somewhere, but I have zero knowledge of pic's etc.. what I'm after is using Suspend (s3), but if I dont start the car say after 24 hours the M1 then goes into HardOff.. this would then save my battery draining until it was below 11v's has it struggles then turning over my engine ?
    What I'm after is..
    Jumper 3 changing from
    5sec / never
    to
    5sec / 24hour
    can this be done
    cheers
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
    Im kinda curious about this too on an M2ATX instead, a software shutdown timer that actually interacts with the PSU would be great
      been running standby for a week now... very very pleased so far.. near instant turnon (3 seconds) and no flat battery as yet.. although I do make sure it cuts off when I put it in the garage at night.
      CdR
        Yes, it definitely can be done. The firmware was posted a year back or more. If you can figure out PIC assembly, you should be able to adjust the timing constants to suit your needs. I have a port to C (forget which compiler I used) laying around here somewhere. IIRC, I made it functionally equivalent to the OEM firmware (probably an older version) but I never got around to giving it a thorough test. My ultimate goal was to add a serial comm link from the PSU so that dynamic PSU settings and monitoring could be implemented (based on GPS location or other user supplied feedback for instance). Fortunately the OEM firmware suited my needs and I never got around to finishing -- you're welcome to it if you want.
        What I'm after is..
        5sec / never
        to
        5sec / 24hour
        can this be done
        cheers
        CdR
        2004 4runner
