DSATX Will Not Provide Power
  • DSATX Will Not Provide Power
    Power line supplies power, and when the car is turned on, the remote does as well, however, the DSATX will not output power through the cable. Any ideas? I tested the power and remote with a primitive signal tester (Basically just a light :-P)
    Can you give a little more detail? Are you connecting up a motherboard? Is the motherboard pulling the green wire to ground? What is the LED doing? Have you read through the manual?
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
      The first question of every support issue.
      How about the Wiki?
        user error
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          In short: yes, I have
            That's hardly a sufficient test.
            Lay your hands on a digital multimeter (DMM) and test the voltage at the DSATX terminals for teh 12v constant and 12v switched. Test them both with key on and key off.
            How about the Wiki?
              I found out that the problem is actually that I'm blowing fuses. What could be causing this? My connections are fine - I have one fuse on the power line, and of course one on the DSATX. It appears random as to which one, but sure enough, one of them always blows when I reconnect the negative terminal to the battery. However, the one on my amplifier DOESN'T blow, which is what is weird to me.
